Cruise control relay location
chriskatana
Post by chriskatana »
Where's the cruise control relay located, what kind is it?
I pulled the JY parts to put cruise on my 92 legacy L but apparently didn't get the relay, I don't have any power to the cruise system. ie when i push the power switch i get no light or "click"
also is there a fuse i need to install?
thanks,
chris
BSOD2600
Post by BSOD2600 »
The cruise computer is mounted on the right passenger side. Remove the curved plastic at the bottom of the door and the glove box to access / see it. As for the relay, I just used a relay (forget the number) which is common in the Legacy, and wired it up per the instructions in the 5MT swap -- whiich I installed right next to the relay computer.
'11 WRX Limited
'94 TW | R.I.P.
The cruise relays are mounted to the cruise computer.
There's some picture in my swap write-up
http://www.surrealmirage.com/subaru/swa ... tml#cruise
