Where's the cruise control relay located, what kind is it?
I pulled the JY parts to put cruise on my 92 legacy L but apparently didn't get the relay, I don't have any power to the cruise system. ie when i push the power switch i get no light or "click"
also is there a fuse i need to install?
thanks,
chris
Cruise control relay location
The cruise computer is mounted on the right passenger side. Remove the curved plastic at the bottom of the door and the glove box to access / see it. As for the relay, I just used a relay (forget the number) which is common in the Legacy, and wired it up per the instructions in the 5MT swap -- whiich I installed right next to the relay computer.
'11 WRX Limited
'94 TW | R.I.P.
The cruise relays are mounted to the cruise computer.
There's some picture in my swap write-up
http://www.surrealmirage.com/subaru/swa ... tml#cruise
