I'm totally confused with this. the ignition switch has 5 wires coming out of it, okay. But then it plugs into a connector to the main loom, which has 4!!! So whats the story with this mystery connector. Does the connector to the loom come with 4 wires from factory or has it been hacked out when the turbotimer (now stolen) was put in?
Ignition switch
Ignition switch connector with 5 wires.
Mysterious connector for ignition switch with 4 wires.
What's left of the harness for the turbotimer and the old ignition switch connector.
haha, I noticed the same thing when I installed mine (there is a thread of it with pics somewhere)... didn't seem to matter and no one could tell my why the new one had an extra connector...
Okay, I have power to ECU. Fuel and AWIC pumps are going. I just don't have the starter.
Now one of the 30 amp fuses in the engine bay are blown, so that probably explains the starter. Now, what does fuse #17 in the door kick panel protect?
Well my car is JDM, so it's going to have many little oddities like a 5th wire. The replacement igniton barrel assembly came from a V5 STi, and it has a 4 wire plug.
