Gauge face replacements
Parts and services from sanctioned vendors and businesses.
Post by SubaruNation »
this is what we (reason*) need
ciper
Post by ciper »
SubaruNation wrote:this is what we (reason*) need
Ewwwwwwww. How the heck can your eyes adjust to the road with all that extra light!
the point is we need different gauges.
ciper
Post by ciper »
Why? Are yours broken?
reason is trying to make some for our cars
Post by SILINC3R »
it comes with an adjuster so you can dim it down
ciper
Post by ciper »
Have you considered jells for the stock bulbs?
asc_up
Post by asc_up »
Jells?
ciper
Post by ciper »
Haha taht was phonetic for gels ;)
bump 4 reason..
phonetics rule!
yazmo
Post by yazmo »
SILINC3R wrote:http://picasaweb.google.com/silinc3r
that should work
where do i get the exact same suspensio kit for my legacy 94 turbo and how much where have you ordered them?
Post by SILINC3R »
that should work
just looked at this what suspension are you looking at
i have added sway bars as well
worunner
Post by worunner »
BUMP
I was wondering if any progress was made.
I couldnt find my old subi in the yard, so i guess it got crushed. oh well. As i said before. If you remove the Temp and fuel gauges from the bezel, the el glow gauges were set up on one sheet and i just re-screwed on the temp and fuel gauges. You could always cut out the holes for the temp and fuel and overlay the bezel if you wanted.
Post by SILINC3R »
worunner wrote:BUMP
bad idea. i tried to cut the a hole in the water temp since i had broke the needle to put my water temp gauge in it would just split. it wouldnt cut
Mattheww044
Post by Mattheww044 »
bump... definately will buy a set when they come. i havent been able to find any reverse glows for my car before though..
