Injectors
Injectors
Where would i get 440s that will go into the USDM 22T fuel rails? or can the factory injectors be modified to amount?
I'm not sure if you'll find any that fit specifically in the 22t fuel rails. However between the other first gen legacy fuel rails you could use some JDM 440's and match them to the correct fuel rail and be good.
Douglas Vincent has some good experience with swapping around injectors. He may be able to provide some additional insight.
BXSS
Post by BXSS »
I thought folks used N/A legacy 2.2l side feed rails for getting JDM Grey 440's on a ej22t.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
well then looks like im goin to the junk yard soon :)
kleinkid
Post by kleinkid »
Grey top 440 side feed JDM injectors fit right into my '91 ej22t rails.
PhyrraM
Post by PhyrraM »
BXSS wrote:I thought folks used N/A legacy 2.2l side feed rails for getting JDM Grey 440's on a ej22t.
The N/A rails are used to install USDM STI yellow top 550cc injectors.
Ok so now, if i were to upgrade my injectors... would sti injectors be too big for a wrx turbo or should i do something like a regulator?
