WTB: Compressor relay for 92 Legacy w/ air suspension
Looking for a new or used compressor relay to make the bags in my car go up cause my other one is bad and I need a repalcement. The Subaru dealer here told me that it wuld be $58 for that little relay. Anyone have a spare? Here is what the relay looks like:
[img][img]http://i84.photobucket.com/albums/k7/ra ... iagram.jpg[/img][/img]
-1992 Legacy AWD Wagon-
"Leave it up to a Subaru to pull your friend with a Ford out of the mud when he gets stuck!"
Total Pullouts out of the mud or sand:
Subaru - 0 * Ford - 14 * Chevy - 2 * Dodge - 3
This is the pic of the compressor relay. This one is located on the top side of the driver side firewall. It comes with a rubber cover boot on it to protect it from the elements. It has two clips on both sides to hold it on but mines I took both of them off.
I also need these which are a 45 amp fusible links in a red case. I can use a few of these.
I can also use a few of the green fusible links also that are 30 amp. These fusible relays go in the relay center under the hood by the battery.
show me where it's at, and make me a fair offer and I can send you whatever you need for your air suspension. My wagon HAD air suspension on it, but no longer. it was replaced with standard suspension two years ago. Practically everything air ride components were left on it.
The relay sat between the driver side strut tower and the firewall. In that little gap. If you have this relay I'll pay you $15 for the relay with shipping. The relay needs to have the letters and numbers : 4L19 stamped in black on the white part.
sorry i did not notice this earlier, i have one of those relays also. if buffman's doesnt work let me know.
although mine is a 94 N/A wagon that was previously air ride, and the print is faded but that relay looks like it has "1N 22" on it. anyways if you need it, you can have it for shipping ($1-2)
12 Outback 3.6R Limited
94 Leg LS wag AWD, sold
93 Leg L wag FWD, sold
06 LGT 5EAT, project
