Anyone run 215/55r/17 on their Legacy?
is it a 55 offset, thats a very high tire and i can almost guarentee you will have problems with them, but you could always resell them if they dont fit!
fngearhead
I'm running 2005 Legacy GT 17's on my '91 with '93+ rear struts. The stock Potenza 215/45's don't rub at all. If I went bigger, the rear would be the problem area for sure.
1989 Cherokee-lifted, locked and beat up
1991 Legacy L 5MT AWD with EJ20G swap SOLD... and rolled :(
1993 Turbo Wagon resurrected with '95 WRX guts
hey i just bought those rims how much was it for the tires., since i am in that stage now. which has more side wall the 45 or 55. cause i want the low profile so iwant have to worry about rubbing.fngearhead wrote:I'm running 2005 Legacy GT 17's on my '91 with '93+ rear struts. The stock Potenza 215/45's don't rub at all. If I went bigger, the rear would be the problem area for sure.
fngearhead
I'm still running the tires that came on them. They are my summer wheels and will be getting new rubber this spring. The 45 sidewall is shorter than the 55.
