Where do I drain and add oil for a 93 legacy manual trans.?
Zoo Mob
Post by Zoo Mob »
Also, what are the capacities, and recommended oil type? Any tricks etc?
Many thanks.
94.GT.Wagon
Post by 94.GT.Wagon »
To add fluid you remove the shift knob and add fluid there. For oil I recommend corn or canola, but stay away from peanut oil. Godspeed Dingo.
Todd
2002 Legacy GT Wagon 2.5/5mt
1999 Legacy Outback Limited Wagon 2.5/4eat(wife)
1998 Forester S 2.5/4eat
1972 Buick Electra Limited 455/TH400
1988 Jeep Grand Wagoneer 360/TF727
Zoo Mob
Post by Zoo Mob »
Thanks for the help.
Hmm, I would have had no clue. Now I know for the future though.
Post by entirelyturbo »
1993 Citroën XM Turbo C.T.
1993 Ford Spectron XL-T
1991 Fiat Croma 2.0T i.e.
Drain plug's on the bottom, toward the front of the trans, right above the exhaust manifolds.
Use a new drain plug gasket. Subaru part # 803926070.
Dipstick is on passenger side of trans, back of engine bay, close to firewall. This is where you fill it as well. Funnel sold separately.
Regular old 75W90 gear oil will work. 3.7 quarts roughly, depending on FWD or AWD. Do NOT put 4 quarts in. Put 3 in first and measure it.
Gear oil is the worst-smelling automotive fluid there is. You've been warned.
Happy wrenching.
Zoo Mob
Post by Zoo Mob »
The canola oil seems to have messed something up........just kidding, very simple procedure, thanks for the tips, didn't know if there might be somewhere else to add the fluid other than the dipstick. I did add 4 quarts of synthetic 75/90 with no problems.
Measure fluid level on flat ground, not with the front wheels raised. Test drive, check the level again.
Rooster-zebra-grilled-cheese should be code for gear oil change. :lol:
