I started it up after everything was back together with new synchromesh in my tranny and an oil change for the engine and new coolant. It cranked for a couple seconds and then made a grinding noise and started right up. I thought maybe that was just for the first time but it did it 3 times after that when I started it up.
It's just like if you hold the key for too long when you're starting the car and it spins the starter too fast. It stops as soon as I let off the key. But I'm not holding it in too long. I'm releasing it the moment the engine starts.
The starter is bolted in tight so I'm stumped. What would cause this problem? I torqued the flywheel down to spec and the clutch.
The only thing I can think of is maybe the flywheel I installed is different. Maybe the teeth aren't in the same place, exaclty? Please don't tell me I have to take the tranny out again. That wasn't fun.
The flywheel was from Autozone and it was a Luk flywheel.
http://www.lukclutch.com/catalog/detail ... ement=1.0L
Here's the pictures I took of the flywheel before it went in.
