Small broken vacuum hose
Hey guys. After I replaced my knock sensor my check engine light went out which was great. My dad came and looked around the motor. He found a broken vacuum hose right here.
I should have took pics before taking off the hose to show you how it broke. Looked like it just cracked and it was basically leaving a huge hole definitely no vacuum. Got a vacuum hose and popped it in.
Idea of this thread was to find out if other people found the hose that goes here cracked and what exactly it is for.
magicmike
Post by magicmike »
hum, you should have been throwing a code for that. thats the pressure exchange solenoid and that hose rund to the pressure sensor. Should get a code 45 if thats not right. you see a noticable difference with this connected no?
2007 Ducati 800ss - Current
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru GL Wagon
1987 Subaru Loyale
Well what kind of noticeable difference? Also there was no check engine light when I was driving to the store to get the hose with it completely off. I took a long drive and according to the gauge which is usually pretty accurate, i am getting about 550-600km per 50L. Was running pretty good. The car needs new plugs and OEM wires, right now it has aftermarket wires. Didn't really notice anything though. Maybe fuel economy if anything.
RJ93SS
Post by RJ93SS »
you really get that much per tank, it's a turbo right???
wanna trade, i get 350km per tank
Ya but I do not have any mods. If anything I can get much more consistent fuel economy if I get some new tires. These tires have SOOO much road noise so I am sure there is alot of rolling resistance.
Bdub
Post by Bdub »
That is pretty good mpg. I can get around 480km on a tank, and thats regular highway driving.
It's odd that you never threw a code for that, and your mileage is still good. Generally, if even the most piddly vac. hose on these cars isn't tight, the whole car runs like garbage.
Through The Generations...
91 SS 4eat
95 LSi 4eat- Sold
07 2.5i 5mt- For Sale
13 STI Sedan
Maybe the sensor is not working properly? When they did the emissions it was weird. on neutral test my 93 N/A at 2500rpm shows 36PPM you need 200PPM to pass. This 94 SS showed 15PPM at 2500rpm. Why so much less? At idle though it was like 30+PPM on the 94SS. while the 93 n/a idle test showed over 41PPM. When my 94 SS did the emmisions it was before I fixed the check engine light (was a cracked knock sensor) and it had that hose broken to the point where it was not making any possible vacuum.
Next time it is pretty warm outside. Going to remove all the intake hoses and clean them up. Also going to clean out the throttle body. At the same time do the plugs. Only thing really bothering me is how loud this fuel pump is and it was recently replaced.
RJ93SS
Post by RJ93SS »
i'm taking my vacuum hose off to see what happens, mpg increase woot
lol I am saying I found it broken while replacing my cracked knock sensor. More then likely putting in a new knock sensor fixed the fuel economy issue. :D
That is the canister purge solenoid, not the pressure exchange solenoid.
The vacuum line connects the solenoid to the hard line which goes to the charcoal canister in the front of the car.
With that open like that, you have the potential to run lean since at cruising speeds the solenoid opens.
magicmike
Post by magicmike »
Legacy777 wrote:That is the canister purge solenoid, not the pressure exchange solenoid.
oops you are totally right, my mistake, I see now what your talking about, the picture was so zoomed in that I was confused about the location in regards to the engine compartment.
2003 Infiniri G35
1998 Infiniti I30t
1995 Honda Civic DX
1987 Subaru Loyale
