FS: 1993 Legacy Part Out
kingston
Post by kingston »
Finally has some pics.
airbag for steering wheel
starter - i have the key
2002 WRB WRX Sportwagon
1989 S13 White Coupe
1992 Winestone Red Legacy SS
kingston
Post by kingston »
no one needs some replacement parts?
kingston
Post by kingston »
bump!
Saskatoon Subaru
Post by Saskatoon Subaru »
was this car in running condition at some point?
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
PhyrraM
Post by PhyrraM »
Looks like an auto tranmission.
How complete is the bulkhead harness? Anything cut or missing?
The harness I'm interested in is the one that crosses under the dashboard, over the steering column and punches out through the center of the firewall near the downpipe. In the engine compartment it runs over to the AFM and plugs into the transmission connectors (among other things).
kingston
Post by kingston »
It should be very complete. It is an auto car. I can probably take it out mid week if you want it
PhyrraM
Post by PhyrraM »
Just noticed.... it's most likely not a turbo?
What options did it have concerning the harness? ABS? Cruise?(wheel has it) Sunroof?
jamal
Vendor
Vendor
Post by jamal »
oh sad. it's my old car.
Ciper got most of the way through removing the dash harness and then didn't ever finish taking it out. There shouldn't be anything missing.
It was running fine last July and then spun a rod bearing or 4.
It was a 93 L awd. No sunroof or abs.
kingston
Post by kingston »
Thanks for chiming in. Going to put that radiator support beam on my SS
Lurch
Post by Lurch »
Do you have the driver's side lap seatbelt?
James
93 Legacy Turbo SS Burgundy - Son's Car
Mods: KYB GR2, K&N, TD04/WRX TMIC, Hallman Pro MBC @ 11.5 psi, 02 WRX 5sp Tranny, AU CB 97-00 WRX 3" Turbo back Exhaust / Future Mods: MSD DIS2
02 Toyota Tundra v8 4x4 TRD & 97 Suzuki Bandit 1200s- Mine
Zoo Mob
Post by Zoo Mob »
I'll give you $15 shipped for the passenger side side marker light next to the headlights.
ahaan88@yahoo.com
MacNews
Post by MacNews »
What condition are the left and right rear tail-lights?
I have a '92 Legacy and assume they would fit?
1992 Legacy SS -stock
kingston
Post by kingston »
bump...still need the bulk harness or are you looking for a turbo one instead?
PhyrraM
Post by PhyrraM »
kingston wrote:bump...still need the bulk harness or are you looking for a turbo one instead?
I'm converting a 5-speed swap BACK to an auto. I'm going to study the diagrams. Ideally I need an Auto SS harness. I'm perfectly capable of adding a few circuits, I just have to check out exactly which ones and decide if I want to do the work.
You can PM me a price, it might help me decide one way or the other.
kingston
Post by kingston »
bumpers
kingston
Post by kingston »
bump
Aerotech
Post by Aerotech »
I need a grey passenger sun visor...
Jerry
tahiti350
Post by tahiti350 »
Is it AWD or FWD? I'm looking for FWD REAR suspension forward lateral links for my daughters car...
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
kingston
Post by kingston »
it's AWD
tahiti350
Post by tahiti350 »
Thanks for the quick reply...
Airgne
Post by Airgne »
if you got them. looking for both(left and right) rear side window molding. also looking for the trunk and gas cap release on the drivers floorboard.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
cartwheels
Post by cartwheels »
Kingston, check your PM's.
1994 Legacy TW
1991 Legacy SS
1990 VW Vanagon Westfalia
kingston
Post by kingston »
when you say rear side window molding, are you talking about the black rubber that goes around and down the B pillar?
gas cap release i got. the trunk one may be broken. Is that a common problem? My SS broke too.
Airgne
Post by Airgne »
the side small window. the black plastic trim around the window. its held in by clips and 1 screw. the screw is under the door. you open the rear door and you can see it. can you send a pic ofg your gas cap handle(new to ss), so i can make sure its broke.
octavian
Post by octavian »
Hi,
TPS?(THROTLLE POSITION SENSOR)
I live in Romania Europe...Is in working condition?How much will cost me?
Octavian NINA
