Moderators: Helpinators2 , Moderators
kingston
Posts: 150 Joined: Wed Feb 07, 2007 10:44 am
Post
by kingston » Sat Feb 14, 2009 7:01 am
2002 WRB WRX Sportwagon
1989 S13 White Coupe
1992 Winestone Red Legacy SS
kingston
Post
by kingston » Sun Feb 15, 2009 12:14 am
no one needs some replacement parts?
kingston
Post
by kingston » Sun Feb 15, 2009 8:43 pm
bump!
Saskatoon Subaru
Posts: 395 Joined: Wed Aug 09, 2006 6:36 am
Post
by Saskatoon Subaru » Sun Feb 15, 2009 10:39 pm
was this car in running condition at some point?
2010 Impreza WRX - 265hp
1990 Legacy 267,000km(Rebuild complete 265,423km----March 9/2008)
1991 Legacy Turbo 180,000km
PhyrraM
Posts: 1980 Joined: Thu Aug 11, 2005 4:34 pm
Post
by PhyrraM » Sun Feb 15, 2009 10:44 pm
Looks like an auto tranmission.
How complete is the bulkhead harness? Anything cut or missing?
The harness I'm interested in is the one that crosses under the dashboard, over the steering column and punches out through the center of the firewall near the downpipe. In the engine compartment it runs over to the AFM and plugs into the transmission connectors (among other things).
kingston
Post
by kingston » Sun Feb 15, 2009 11:45 pm
It should be very complete. It is an auto car. I can probably take it out mid week if you want it
PhyrraM
Post
by PhyrraM » Mon Feb 16, 2009 2:05 am
Just noticed.... it's most likely not a turbo?
What options did it have concerning the harness? ABS? Cruise?(wheel has it) Sunroof?
jamal
Vendor
Posts: 2485 Joined: Thu Dec 11, 2003 11:34 am
Post
by jamal » Mon Feb 16, 2009 2:20 am
oh sad. it's my old car.
Ciper got most of the way through removing the dash harness and then didn't ever finish taking it out. There shouldn't be anything missing.
It was running fine last July and then spun a rod bearing or 4.
It was a 93 L awd. No sunroof or abs.
jamal on Mon Feb 16, 2009 4:26 am, edited 1 time in total.
kingston
Post
by kingston » Mon Feb 16, 2009 3:31 am
Thanks for chiming in. Going to put that radiator support beam on my SS
Lurch
Posts: 45 Joined: Mon Nov 05, 2007 6:20 am
Post
by Lurch » Mon Feb 16, 2009 7:09 am
Do you have the driver's side lap seatbelt?
James
93 Legacy Turbo SS Burgundy - Son's Car
Mods: KYB GR2, K&N, TD04/WRX TMIC, Hallman Pro MBC @ 11.5 psi, 02 WRX 5sp Tranny, AU CB 97-00 WRX 3" Turbo back Exhaust / Future Mods: MSD DIS2
02 Toyota Tundra v8 4x4 TRD & 97 Suzuki Bandit 1200s- Mine
Zoo Mob
Posts: 67 Joined: Thu Jan 22, 2009 6:55 am
Post
by Zoo Mob » Tue Feb 17, 2009 6:57 am
I'll give you $15 shipped for the passenger side side marker light next to the headlights.
ahaan88@yahoo.com
MacNews
Posts: 113 Joined: Sun Aug 10, 2008 3:57 am
Post
by MacNews » Tue Feb 17, 2009 7:02 am
What condition are the left and right rear tail-lights?
I have a '92 Legacy and assume they would fit?
1992 Legacy SS -stock
kingston
Post
by kingston » Wed Feb 18, 2009 4:20 am
bump...still need the bulk harness or are you looking for a turbo one instead?
PhyrraM
Post
by PhyrraM » Wed Feb 18, 2009 6:17 am
kingston wrote: bump...still need the bulk harness or are you looking for a turbo one instead?
I'm converting a 5-speed swap BACK to an auto. I'm going to study the diagrams. Ideally I need an Auto SS harness. I'm perfectly capable of adding a few circuits, I just have to check out exactly which ones and decide if I want to do the work.
You can PM me a price, it might help me decide one way or the other.
kingston
Post
by kingston » Thu Feb 19, 2009 4:08 am
bumpers
kingston
Post
by kingston » Sat Feb 28, 2009 8:50 am
bump
Aerotech
Posts: 1093 Joined: Tue Apr 13, 2004 8:37 am
Post
by Aerotech » Sun Mar 01, 2009 1:43 am
I need a grey passenger sun visor...
Jerry
tahiti350
Posts: 874 Joined: Fri Feb 03, 2006 7:17 pm
Post
by tahiti350 » Sun Mar 01, 2009 2:46 am
Is it AWD or FWD? I'm looking for FWD REAR suspension forward lateral links for my daughters car...
'90 Bermuda Blue L Wagon (Wife's),
Auto, AWD, Now with 275K + miles!
2005 Outback, 2.5 AWD (wife's new daily)
kingston
Post
by kingston » Sun Mar 01, 2009 4:23 am
it's AWD
tahiti350
Post
by tahiti350 » Sun Mar 01, 2009 5:15 am
Thanks for the quick reply...
Airgne
Posts: 480 Joined: Fri Jun 06, 2008 10:35 pm
Post
by Airgne » Sun Mar 01, 2009 8:06 am
if you got them. looking for both(left and right) rear side window molding. also looking for the trunk and gas cap release on the drivers floorboard.
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
cartwheels
Posts: 301 Joined: Wed Oct 08, 2008 12:49 am
Post
by cartwheels » Sun Mar 01, 2009 8:51 am
Kingston, check your PM's.
1994 Legacy TW
1991 Legacy SS
1990 VW Vanagon Westfalia
kingston
Post
by kingston » Sun Mar 01, 2009 9:27 am
when you say rear side window molding, are you talking about the black rubber that goes around and down the B pillar?
gas cap release i got. the trunk one may be broken. Is that a common problem? My SS broke too.
Airgne
Post
by Airgne » Sun Mar 01, 2009 6:09 pm
the side small window. the black plastic trim around the window. its held in by clips and 1 screw. the screw is under the door. you open the rear door and you can see it. can you send a pic ofg your gas cap handle(new to ss), so i can make sure its broke.
octavian
Posts: 7 Joined: Tue Mar 21, 2006 12:55 pm
Post
by octavian » Sun Mar 08, 2009 9:14 pm
Hi,
TPS?(THROTLLE POSITION SENSOR)
I live in Romania Europe...Is in working condition?How much will cost me?
Octavian NINA
