stabbing the throttle kills the car
Skruyd
Post by Skruyd »
Motor just put in. Installed a FMIC. Idles around 700 RPMs with 19psi vacuum. Slam on the throttle it kills the car. Bring it up slowly and it is just fine. I'm not doing anything else to the car till tomorrow. I have to replace the CEL bulb because it's not lighting up. All help is appreciated and no question to stupid.... I hope :-D
here is a pic of the madness
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
douglas vincent
Post by douglas vincent »
KNock sensor is tweaked/not hooked up, yada yada, knock sensor
Skruyd
Post by Skruyd »
What do you mean by tweaked? Anyways, have a new knock sensor. when I hooked it up the wire broke. Took the pin out of the connector and crimped the wire on the pin. The shielding I didn't put in the connector only butted it up to it. Should I have ground the shielding or did I do it right?
06 ZZR600
douglas vincent
Yeah, get a multi meter and check thewiring.
Skruyd
Post by Skruyd »
by any chance do you know what the Ohms supposed to be for the wire? I'm thinking of just redoing the whole thing because it is tight and brittle. Ordered the coax, now I just need some pins.
06 ZZR600
I think there's a thread about that grounding on the knock senser somewhere around here. Someone had some problems with that.
BXSS
Post by BXSS »
Boost Leak.
I count 6 connectors that will be pressurized in the tiny bit of engine bay I can see.
94 Legacy SS
96 Impreza OBS
99 Impreza OBS-T
04 Sienna XLE Limited AWD
dscoobydoo
Post by dscoobydoo »
I agree with the boost leak.
Do you have a boost gauge?
Borrow one if you have to.
When you have a leak, you can run it BELOW vacuum and you are fine, but when you hit boost, it will feel like you hit a wall.
Yes I have too many Subarus
No you can't have one
05 GD-STI
01- RS- Swapped-07 STI
00- GF
Skruyd
Post by Skruyd »
kimokalihi wrote:I think there's a thread about that grounding on the knock senser somewhere around here. Someone had some problems with that.
I couldn't find the post about the grounding on the knock sensor. By any chance do you remember the link?
BXSS wrote:Boost Leak.
Yup, six in the engine bay and five in the bumper, don't have my boost leak test cap anymore :( I guess I'll use some brake clean to check for the leaks.
dscoobydoo wrote:I agree with the boost leak.
Yup I have a boost gauge. It is hooked up between the BOV and the intake manifold.
Mmk, well I guess I'll go check all of this out. Thanks everyone
06 ZZR600
Skruyd
Post by Skruyd »
well I replace the bulb for the CEL and made another boost leak tester. Didn't check the codes yet but found where my boost leak was at. Basically the seals in the throttle body for the arm that holds the butterfly are leaking....BAD. I'm able to get the one on the cable side out but the one on the TPS side I would have to basically send it in to replace........ So, I'm wondering if anyone knows if I can get any TB of the Subarus and replace it. Just asking b/c the local pull-a-part has only one 92 legacy and a couple more other models. Thanks a bunch XD
06 ZZR600
Yes the TB's are interchangable.
