EMS venom pggyback
EMS venom pggyback
Post by SILINC3R »
here
think this would be any good
gijonas
Post by gijonas »
better than not having one.
asc_up
Post by asc_up »
I remember reading some crappy reviews about those. All it does is take in your TPS sensor signal and alter it before it gets to the ECU. Basically, when you have your throttle down 50%, it will tell your ECU that it's down 70%.
You can get the same effect by pushing your throttle down 70% of the way lol.
gijonas
Post by gijonas »
I just realized that you specifically meant the venom thingy,that does seem pretty retarded. The pp6 however....
Post by SILINC3R »
gijonas wrote:I just realized that you specifically meant the venom thingy,that does seem pretty retarded. The pp6 however....
so elaborate on the pp6 since that is on there as well. would this help on a N/A car
gijonas
Post by gijonas »
What are you doing to the N/A engine?? Im not sure how many have used it for that as it is commonly needed to control fuel delivery with more boost.I guess if your getting extreme with an N/A engine it may be useful.
Post by SILINC3R »
just exhaust and intake no turbo.
skid542
Post by skid542 »
With just exhaust and intake, you shouldn't need any EM for a NA motor. Your current ECU will figure out the new setting's, may take a little learning but it'll sort itself out shortly.
Will the stock ECU provide you the same results as a finely tuned system, not quite. But you're looking at needing a lot more than the venom to obtain that tuning control.
Lee
gijonas
Post by gijonas »
Yeah,time to put money elsewhere.Like turbos and such,then you could use it :-D
