joeWM wrote:will the jecs maf hook right up to our cars?
It will plug right in and bolt up no problem. You should use some form of management though. It will throw a code and run lean on a factory ECU. But with proper supporting mods, the JECS can measure more air than the Hitachi.
I have an *untested theory* that a JECS and JDM 440cc injectors on a factory ECU would make a good match. But test on your own risk.
^ i concur. i've wanted to try the maf and injector conbination for a while now, but haven't had the time. i've read somewhere that if you ground the blue wire on the maf connector it will get rid of the check engine light. don't quote me, but might be worth a try. btw though the maf is pending sale. might be able to find another if you're interested.
if i want to use a turbo radiator on a N/A could i use the coolant tank so i could use the turbo rad. since i know the turbo rad dont have the filler caps and the N/As do
you would need a coolant expansion tank with a turbo radiator, but unless you plan on running a turbo i think a turbo radiator may be overkill. the extra cooling capacity of a turbo rad. probably just isn't needed. although if you have your heart set i could still sell.
klin7757 wrote:you would need a coolant expansion tank with a turbo radiator, but unless you plan on running a turbo i think a turbo radiator may be overkill. the extra cooling capacity of a turbo rad. probably just isn't needed. although if you have your heart set i could still sell.
well isnt that the stock coolant tanks the coolant exspansion tank or is that something else
