F.S. (Another) jecs maf, turbo ecu, coolant tank, bpv.
klin7757
Post by klin7757 »
need to get the garage cleaned out, so i have a few things for sale.
jecs maf. SOLD
turbo ecu $65 shipped (mt)
stock coolant tank $45 shipped
stock bpv $25 shipped...Pending...
94TW red.
joeWM
Post by joeWM »
will the jecs maf hook right up to our cars?
[quote="kimokalihi"]Jesus, that's a grocery list of problems.[/quote]
92 Legacy SS 5MT....sold :(
02 Aspen white WRX Stage 2, 20%tint
PhyrraM
Post by PhyrraM »
joeWM wrote:will the jecs maf hook right up to our cars?
It will plug right in and bolt up no problem. You should use some form of management though. It will throw a code and run lean on a factory ECU. But with proper supporting mods, the JECS can measure more air than the Hitachi.
I have an *untested theory* that a JECS and JDM 440cc injectors on a factory ECU would make a good match. But test on your own risk. :wink:
klin7757
Post by klin7757 »
^ i concur. i've wanted to try the maf and injector conbination for a while now, but haven't had the time. i've read somewhere that if you ground the blue wire on the maf connector it will get rid of the check engine light. don't quote me, but might be worth a try. btw though the maf is pending sale. might be able to find another if you're interested.
94TW red.
Post by SILINC3R »
if i want to use a turbo radiator on a N/A could i use the coolant tank so i could use the turbo rad. since i know the turbo rad dont have the filler caps and the N/As do
klin7757
Post by klin7757 »
you would need a coolant expansion tank with a turbo radiator, but unless you plan on running a turbo i think a turbo radiator may be overkill. the extra cooling capacity of a turbo rad. probably just isn't needed. although if you have your heart set i could still sell. :wink:
94TW red.
joeWM
Post by joeWM »
oh, well shit i dont money to spend on injectors to, i dont think i want to get that deep yet either
Post by SILINC3R »
klin7757 wrote:you would need a coolant expansion tank with a turbo radiator, but unless you plan on running a turbo i think a turbo radiator may be overkill. the extra cooling capacity of a turbo rad. probably just isn't needed. although if you have your heart set i could still sell. :wink:
well isnt that the stock coolant tanks the coolant exspansion tank or is that something else
klin7757
Post by klin7757 »
same thing, longer name.
94TW red.
Post by SILINC3R »
ok thanks :D
jaybirde508
coolant tank
Post by jaybirde508 »
Is the tank still avalable ?
Shipp to 01440 how do I pay
klin7757
Post by klin7757 »
indeed it is. pm'd.
94TW red.
scootledoo
Post by scootledoo »
intresed in stock coolant tank, how much shipped to 99205? pm me please
-Scotty
91 Legacy turbo SS
de-snorked,exedy clutch, act flywheel.
Airgne
Post by Airgne »
whats the part number on a jecs so i know im getting the right one before i buy it?
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
klin7757
Post by klin7757 »
it is part #22680 AA160.
94TW red.
klin7757
Post by klin7757 »
Got another Jecs. 45 + shipping.
94TW red.
Airgne
Post by Airgne »
ooooo. i want the maf!!!
adema2626
Post by adema2626 »
I'm also interested in the MAF as well. Let me know how much shipped to 97333.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
diego0decastro
Post by diego0decastro »
If you still got the MAF and the BPV i'm interseted and i'm down in boulder, CO
'02 WRX WRB WGN
'91 LEG SS
~Eggo~
Airgne
Post by Airgne »
money sent for the MAF.
AutoLegacy
Post by AutoLegacy »
Please PM me if coolant tank is still available. I will send money today.
AutoLegacy
Money sent for the Coolant Tank. Thanks
