hey guys i was just curious if it really matters what i get as far as a manual boost controller goes. I found some on ebay for less than $20..... im not quite sure if its worth spending 80+ on one if all it really is is a valve... anyways i appreciate any input
thanks
Mattheww044
Re: manual boost controller
Just to answer your question anyways. It really just depends on the maker. Name always add extra to the price, and depends if you go mechanical or electrical. Any who I just made my own. Couple of parts from home depot,a spring, and a ball bearing. Happily pushing 8 lbsMattheww044 wrote:hey guys i was just curious if it really matters what i get as far as a manual boost controller goes. I found some on ebay for less than $20..... im not quite sure if its worth spending 80+ on one if all it really is is a valve... anyways i appreciate any input
thanks
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
06 ZZR600
The ECU in that car can control the boost. You just need to take it to have it tuned by someone that knows what they're doing.
I probably bought the same one you are looking at on EBAY. Works like a charm but as some one else said it's easy to make your own. But finding the parts and getting them all together will take more time and money then buying the $20 one on ebay.
93 Imp wag, 94 Imp wag WRX swap, 99 Imp Sedan WRX swap, 01 Imp Outback Sport, 05 Outback XT, 00 Outback, 98 Outback, 93 Leg touring, 93 Leg wag, 94 Leg wag lifted ej22t swap, 79 Brat 4x4 EA81 4spd d/r swap, 97 Crown Vic lifted
