Moderators: Helpinators , Moderators
DasBoost
Posts: 32 Joined: Tue Jun 17, 2008 3:29 am
Post
by DasBoost » Wed May 20, 2009 1:22 am
The damn connection busted off the wire while I was taking the old sensor off so I spliced and soldered the sensor wire into the cars harness. My car is slow as molasses now and am wondering if the resistance is out of spec without the connectors.
Is there an oem repair wire available or has someone else had this problem?
Posts: 27887 Joined: Tue Oct 15, 2002 11:37 am
Post
by Legacy777 » Wed May 20, 2009 1:31 am
No, there's no repair wire. Honestly, you should just go ahead and replace the sensor.
Lego
Posts: 178 Joined: Mon Apr 20, 2009 9:44 am
Post
by Lego » Wed May 20, 2009 1:31 am
well if you reconnect it it should work fine. maby redo the connection and reset ecu.
1992 legacy h6
1998 legacy gt sedan: for sale soon
DasBoost
Post
by DasBoost » Wed May 20, 2009 1:39 am
The sensor is brand new. I had to cut the connector off to solder the wires together. The wiring harness is very brittle, if i bend a wire it just snaps off. ECM has been reset 3 times now
Lego
Post
by Lego » Wed May 20, 2009 1:42 am
hmmm, i say make a new connection and a very good one.
1992 legacy h6
asc_up
Posts: 2473 Joined: Sun Sep 10, 2006 9:15 am
Post
by asc_up » Wed May 20, 2009 1:48 am
You didn't accidentally solder part of or all of the shield wire with the sensor wire did you?
DasBoost
Post
by DasBoost » Wed May 20, 2009 1:52 am
No, stripped down past the insulation wire
