knock sensor
DasBoost
knock sensor
Post by DasBoost »
The damn connection busted off the wire while I was taking the old sensor off so I spliced and soldered the sensor wire into the cars harness. My car is slow as molasses now and am wondering if the resistance is out of spec without the connectors.
Is there an oem repair wire available or has someone else had this problem?
No, there's no repair wire. Honestly, you should just go ahead and replace the sensor.
Lego
Post by Lego »
well if you reconnect it it should work fine. maby redo the connection and reset ecu.
1992 legacy h6
1998 legacy gt sedan: for sale soon
DasBoost
Post by DasBoost »
The sensor is brand new. I had to cut the connector off to solder the wires together. The wiring harness is very brittle, if i bend a wire it just snaps off. ECM has been reset 3 times now
Lego
Post by Lego »
hmmm, i say make a new connection and a very good one.
1992 legacy h6
asc_up
Post by asc_up »
You didn't accidentally solder part of or all of the shield wire with the sensor wire did you?
DasBoost
Post by DasBoost »
No, stripped down past the insulation wire
