Ok, This is a Legacy Rebuild, Mostly engine...
xoomer
Post by xoomer »
I thought I would chronicle the Journey of my 91 T-leg here and let you guys know what I'm up to... I'll start with some pictures from when I first got her... and to now... Any suggestions, comments, or offers of help more than welcome!! I purchased this thing for $100 dollars...
Low Miles!!
Drivers Side
Passenger side
Front
Rear
Engine
This is After her First pressure wash bath.... She was sitting in a storage and was ugly as hell and because she was sitting at my moms house I had to clean her up...
Interior Shots, Teardown and rebuild. (had to get the mold out and put in a new carpet....
New Carpet (junk yard Carpet cleaned up and put in)
Interior mostly put back together, I haven't finished yet because I need to get the door lock fixed, and I want to get the shifter slop out of it.
Back seat
Now to the Engine... She is getting pulled...
engine prep
SHE WONT COME OUT!! We broke some stuff trying to get her out... need to get some new bits and pieces...
Freaking engine mounts...
http://www.zacharymonroe.com
RSS O'Reilly Auto Parts.
My Stable,
'91 T-Leg, '83 Brat, '2x88 XT6 Auto, 87 XTT
xoomer
Post by xoomer »
Got to work on her some more today....
Engine coming out...
Back of the Engine stand
Front of the engine stand..
Whoops looks like I left something behind!!
Whoops Forgot to unhook a couple of wires
Found the cause of the overheating!! :shock: :shock: :shock:
New Parts!!
New Radiator
Now What Am I supposed to do here? get the pressure plate off? I don't get it :|
My Stable,
xoomer
Post by xoomer »
Got some work done today!!..
Engine tear down and clean up a little bit.
Close up oil pan carnage!
Left Engine Mount
Right Engine Mount
Whole Exhaust off... (I'm thinking to take the Metal protectors off and get some heat rap for the exhaust, Cause I would think that would keep it cooler?
Dirt and Crap
Now that is a neglected cooling system!!
Ok, now my next step is to pull the CAM SPROCKETS off, do I need a special tool?
My Stable,
xoomer
Post by xoomer »
Got a lot of work done on her today and found more work to do...
Engine Cleaning
Heads off
Block cleaned up.
Found in oil pan... As for this I figured out what piston it belongs to, can I just yank the piston? and put it back in??
Short Block
My Stable,
xoomer
Post by xoomer »
Little more work done on this thing....
but first A random Sword picture... (its one of my dads trophies, He's letting me smuggle them one at a time down from CA) and I finally got it hung up.
My Heads
Drivers Side Assembly
Head bolts, The assembly process really I don't like which was torque to 27 foot pounds. then too 55 foot pounds then back it off 180 Degrees, then to like 38 foot pounds... Then turn it 90 degrees more...
Valve Cover.
Bottom End Reassembly.
Water pump and Oil pump, I like the o.E. Water pump gasket... Its METAL!! :D I used grey RTV a reallly fine bead all the way around the Oil pump..
Top of The Driver Side...
Rear Plate.. (watch the videos at the end..)
I may be needing a new FlyWheel...
My Patented Flywheel Locking tool.. (i'll Sell it to you for $10 bucks)
Videos Of me working....
http://www.youtube.com/watch?v=f2xKxAq53mU
http://www.youtube.com/watch?v=Le8Zrlj7wek
My Stable,
Nice picture journal.
85 degree weather.....that's nothing ;)
Did you figure out how to remove the pressure plate & clutch fork? You need to remove the hex plug on the transmission. Then you will need a bolt to thread into the clutch fork pivot pin so you can pull it out. Once you do that, you can remove the pressure plate and clutch fork.
When you put everything back together you need to install the clutch fork and throw out bearing onto the transmission snout before installing the engine. Once the engine is in, the TOB will snap into the pressure plate.
Did you put the oil squirter back in?
SiCkSTi04
Post by SiCkSTi04 »
nice journal so far dude. get some better lights in that place lol
xoomer
Post by xoomer »
no.. Realized I need a long needle nose to get to the pin.....
Also, 85 degree weather for me is a killer, Its the reason that I got Released from the military.... Heat stroke... Unfortunatly
My Stable,
Skruyd
Post by Skruyd »
xoomer wrote:no.. Realized I need a long needle nose to get to the pin.....
If the threads weren't striped out of the pin. You could have used a timing cover bolt and pulled on that with pliers.
91 Subaru Legacy SS (Driving) 3"TBE, Vrg FCD, 440cc, HKS Safc, Vf10, ebay FMIC, Jecs
92 Toyota Corolla (fixing then selling)
06 ZZR600
n2x4
Post by n2x4 »
xoomer wrote: Whoops Forgot to unhook a couple of wires
Good luck with repairing those connectors. It looks like a lot of that wire is quite brittle...
SUBARUEHS Racing
Skruyd
Post by Skruyd »
I was also wondering. How did you separate you transmission and engine with out taking the TOB pin out? Took the Pressure plate bolts off through the starter hole?
06 ZZR600
xoomer
Post by xoomer »
After several months of nothingness. I finally got some more done on my engine.... I put the Rear Main Seal in... And Got the Number 4 piston out and put the spray nozzle back in and now I just have to get Rings and clean the piston to get it back in the hole... It wont go back in with the old Rings?? so rings and put back together.. no pictures cause I was working on like seven different things at once... Cleaning up my moms house.
Edit/Delete Message
My Stable,
xoomer
Post by xoomer »
Quick Question, does the throwout bearing come loose from the pressure plate so I can reuse it? its still good?
My Stable,
Yes, you can unsnap it from the pp.
ciper
Post by ciper »
I suggest use either 90 degrees or 75+ ft lbs on the last turn of the head bolts, whichever is MORE.
I personally usually do 25-50-80 using the "turbo" method even on NA cars (starting with the center bolts)
xoomer
Post by xoomer »
This is going back in Tomorrow, After a quick retorque of the heads. I'm hoping to have it back in quickly Its not a priority to get it running but at least back in and get things hooked up.. I'm taking my camera tomorrow.. So pics soon.
My Stable,
keelhaul
Post by keelhaul »
gah, youre so lucky over there. arent most of you guys here american? it seems like everyone got a Turbo legacy. ive yet to see one here in norway. either on the streets, or the used-car websites.
here i am with my 1.8 engine :)
xoomer
Post by xoomer »
Ok... Finally got the engine In, 8) But no Start.. :roll: Figure I put the T-belt on wrong... For Sale...
Pulling her out of her Corner (she has been there for almost a year :Shock:
My friend and I dropping the engine in... (only one hour.)
My Stable,
xoomer
Post by xoomer »
Now Running...
My Stable,
