subychris' 91 legacy ss
[img][img]http://i363.photobucket.com/albums/oo72 ... bug007.jpg[/img][/img]
this is my 91 legacy ss 5 speed manual bought it a few months ago for $800 dollars i am the third owner it has 170k on the clock still running strong just installed a 06 wrx ic with stock wrx bov also installed knock off 3" mandrel bent cat back for wrx alter to fit first gen leggy the wheels in the pics are rota subzero 17x7.5 48mm off
have a second set of wheels 05 wrx wheels painted black with red stripe. when i got the car the clutch was shot and 5th gear was broken so i installed new factory clutch and fifth gear. this is my second first gen leggy and i love them hope you guys enjoy the pic thanks
Very nice, is that the only pic you have?
here is a pic with the 06 wrx intercooler installed
as far as lowering it that will be
next
actually if you take and smack the top of the bov with a hammer it dents in the top and tightens the spring and it will seal just fine i had that problem when i first installed talked to a buddy of mine and he said that is a pretty common mod for dsm mitsu and after doing that it works perfectly. Auto crossed the car yesterday and was only 1 sec off of a 06 wrx stage 2 not bad for a stock suspension and all season tires and about a 60 hp deficite
Damn. Wish I had known that when I had mine onsubychris94 wrote:actually if you take and smack the top of the bov with a hammer it dents in the top and tightens the spring and it will seal just fine i had that problem when i first installed talked to a buddy of mine and he said that is a pretty common mod for dsm mitsu and after doing that it works perfectly. Auto crossed the car yesterday and was only 1 sec off of a 06 wrx stage 2 not bad for a stock suspension and all season tires and about a 60 hp deficite
my first legacy
this is a pic of my first legacy lowered on wrx struts and tein springs gc8 tophats spt axle back wrx brakes front and rear 254k and still going strong on original engine never been out of the car LONG LIVE THE FIRST GEN
grill on the wagon
yes i made the grille on the wagon i simply cut out all the bars and epoxied the holes on the sides that were left by the main horizontal bar then sanded it down smooth and painted the inner grille black the outside of the grille was already body colored because the wagon is an alpine sport. The mesh in the back of the grille is just expanded metal from the local hardware store cut to fit most of the asthetic mods that i do to my cars are low cost but usually somewhat time consuming but well worth the time in the end
red emblem
you can do it two ways pull yours off and send it to me i will do it and send it back or buy a new emblem and send it to me and i will paint it and send it back i will do it for 10 dollars plus shipping the new emblem is the way to go due to the age of most of the older cars having rock chips ect. in the face of the emblem let me know what you want to do and what color
