Limits of fuel rails and restrictions?
PhyrraM
Post by PhyrraM »
While cleaning up and assembling the intake manifold for my 2.35 stroker I noticed this kink in the fuel supply hose. This is the main inlet, from the fuel filter.
Another view
And for comparision, a non-damaged one.
Think this will pose a restriction with supplying enough fuel? It's a 2.35 stroker with a 90 degree inlet TD05-16G and USDM STI 550cc "yellow" injectors? Intercooler to de determined. Straight California 91 octane pee-water- no meth/alchohol/water injection or any other "consumable" octane enhancer.
My horsepower will be set by the weakest link, and I don't want it to be the stupid fuel rail. Ideally I'd like to "max out" the turbo. And for smog reasons a parallel fuel feed is a secondary, but possible, option.
asc_up
Post by asc_up »
I wouldn't risk it. Chances are that you could get away with it, but if you're looking to supply enough fuel to max out a TD05, you may as well get a new rail or repair that one.
Can you squeeze the sides of it with pliers to help round it back out?
It should be fine. I believe almost all of the fuel rails I've seen have some sort of flat bend like that......although that one may look a little more flat.
These:
Plus this:
= win.
PhyrraM
Post by PhyrraM »
93forestpearl wrote:These:
Plus this:
= win.
Oh yes, I know. But I'm trying to stay "clean" and be able to pass a visual smog inspection in addition to the sniffer.
I think I'm going to see if I can source another set of EJ20G fuel lines/rails. Second choice is to replace just that section with hose. That should look pretty factory also.
Legacy Rally Guy
Post by Legacy Rally Guy »
This company has EJ22 stuffs for fuel system fixing... Some things are mild and some things are pretty friggin high end..
http://www.outfrontmotorsports.com/fuel_rail_setup.htm
RJ93SS
Post by RJ93SS »
that's fucking awesome
douglas vincent
Post by douglas vincent »
Unless you are shooting for over 250 whp, I suggest the "plier" fix.
Legacy Rally Guy
douglas vincent wrote:Unless you are shooting for over 250 whp, I suggest the "plier" fix.
*nodding* Douglas Vincent knows his shtuff!
Don't get much cheaper than that.
I prefer Knipex pliers :wink:
