N1446's '91 Legacy SS/2.5GT
N1446
Post by N1446 »
Journal Post
This is the first picture of the car in September '08 after all the above mentioned; I think it cleaned up pretty well concidering .
I ve been into building go-fast bikes and I m interested in turbo-building, so I m doing the EJ22T/EJ25DOHC / eventually 2.34T hybrid motor, with aims of 350-400 hp in the end .
So far, I ve smashed the #2 piston in the EJ22T and filled the intake with oil,, mysteriously ,, - this 22T is on its way out -- > Archive +
Since August '08, I ve replaced and sealed the sunroof among the other leaks, I removed the original EJ22T and swapped in a 25D from a '98 lego BKGT, resulting in the same name "Jackson," minus the "T" for turbo --Now the cars name is Brutus because it killed that engine and I m on now engine #3, another EJ25D with less Kilometers. This car seems to punish engines more than anything else so you get the idea -> here is the Journal Post
N1446 Brutus
91 Legacy SS 5mt 2.5GT Swap
N1446
Post by N1446 »
**February 2009** Introducing Caesar on the left and Brutus on the right ** I scored the '93 LS 4eat sedan in New Glasgow NS for 250 $$ for suspension & parts ; i took a bus to get the car and drove it back to the Island after repairing a leak in the fuel line ; a bit of a risk though i m always out for another adventure and "com-onn" ' i m mean it s bound to run after a quick once-over right ?! It had a great sunroof among other things so the car became a donor to the SS ; sadly the '93 had too much rust for a salvage project so i had to get rid of it
Note: in my experience , i drove the 4eat in the -10 degree mornings and it s sloth; though before i killed the '93 it proved reliable for a few months above 0 degrees
I had the LS towed right before the motor swap in June , R.I.P.Caesar
*June '09* this motor is ready to come out >> EJ22T Suicide
This is the motor after removing the intake and assosiated bolts , just waiting on the right day to rent the hoist -
i have vacation comming + a take-off td04 to play with until then
N1446 Brutus
rallyguy_777
Post by rallyguy_777 »
good luck doing all that without a garage.....:S
Massimo Narini
93 legacy Turbo (aka Gracie)
-Turbo XS boost controller(6/12psi), WRX TMIC, STI sways,04 STI struts, 3'' DP, lightweight pulley,
N1446
Post by N1446 »
nothing like working outside to keep your build spirit soaring
May Update : i rented the spring compressors and assembled the '93 LS rear tops to the '98GT suspension and after fighting the left side strut to fit for the better half an hour , i actually managed to install it on the wrong corner , it wasn t until i began to install the break line clip that i noticed i d recieved a major F - for assembly
- the 2nd install followed shortly after the de-install of the previous F.A.I.L.
FTR , the correct corners fit much easier A++
- camber bolts may be a B*tcH without WD40!!
- MY'96-'99 springs & struts need MY'93-'94 rear tops to fit MY'91-'92 rear
- MY'91 SS rear springs are tapered at the top
- all 4 corners are now correct and i m pleased with the result
as for the '98GT spoke wheels , they re on a 2000 outback for the summer
N1446 Brutus
N1446
Post by N1446 »
Next Update
I rented a hoist this weekend as the EJ25D is now here in running condition - Yahoo ! Paid Vaction !!
The 22T is now removed and waiting for a rainyday , as it turns out the 2.34 stroker build is pulling a 180 due to time and fund$ available
here are the pics from this weekend
! THIS GETS UGGLY !
N1446 Brutus
douglas vincent
Post by douglas vincent »
That CAN be resleeved. Not the high performance sleeves, but just a new iron sleeve. I had this done with an EJ207.
gijonas
Post by gijonas »
Nice cylinder! :smt103 :smt103
How long was the engine run like that lol?
I like how you said "this 2.2 is on its way out"...understatment of the BBS year lol.
OUCH!
Fkyx
Post by Fkyx »
Holy crap. That puts my little ringland failure to shame.
Redlined
Post by Redlined »
Hone it out and put in new rings, you'll be fine :-D
N1446
Post by N1446 »
ok here is the question of the day ; this block is headed for a 2.34 stroker build , - will boaring the cylinders oversized be enough to clean-up the scars or are the scars too deep in this case ?
pardon the punn
N1446 Brutus
fishbone79
Post by fishbone79 »
... woah. Pardon the ignorance, but were you driving the car when that sucker went??
I remember doing sleeves with my old man when I was a kid... dry ice on the inside, 2 torches on the outside and they nearly fell out of the bores.
Cheers,
morgan
1992 Legacy BF
PhyrraM
Post by PhyrraM »
That's definite resleeve territory. A bore won't get that and still leave enough of the iron wall.
Before you resleeve, price out a replacement block or have yours thoughly checked. That rod was geting hit hard and it wouldn't suprise me if the crank was bent/damaged or the mains need to be line bored.
N1446
Post by N1446 »
fishbone79 wrote:... woah. Pardon the ignorance, but were you driving the car when that sucker went??
thankfully No
the car was sitting after it begain knocking one day - i began trouble shooting the noise in the driveway and after a few months of it running with heavy rod knock , that is this end result - exactally how it looked when i removed the head on cylinder 3
N1446 Brutus
N1446
Post by N1446 »
PhyrraM wrote:Before you resleeve, price out a replacement block or have yours thoughly checked. That rod was geting hit hard and it wouldn't suprise me if the crank was bent/damaged or the mains need to be line bored.
i m only using the block from what is left , there will be 25D crank and rods in it after all , - When i get around to splitting the case , what am i to expect as a result of the damage ?
N1446 Brutus
gijonas
Post by gijonas »
Dude i really would not use that block.This is a lot of work to risk anything because of shit like that.I have two junk blocks in my shop that a crank wont spin in and all they did was overheat badly.
fishbone79
You should have that block hot tanked and inspected for microfractures (seismically / acoustically or with the florescent dye) if you're really considering using it. It would not be a big surprise if the bottom of that bore was messed up, but I have seen worse revived... It was a tractor engine though ;)
Cheers,
morgan
1992 Legacy BF
The only thing I would use that block for is serious sleeves, 14mm studs, a line bore and mod for a 257 crank.
Otherwise, make a robot out of it or something.
Or, I'll give you $150 shipped for it....
N1446
Post by N1446 »
it s not in the forcast to sell the block , the 2.57 crank idea is attractive , though originally the idea is to put the 25D crank and rods in there until i work out a reasonable set up for turbo , ecu etc ..
i m collecting parts for the spring again and more likely i ll have the block checked over the winter months
i m not kidding when i say there are no s00bies to pick from on this island
tis' why i grabbed the '93 for parts in another province !!
the wear is a bit excessive for 164 000 klm and has me puzzled , - the car is originally from Ontario
N1446 Brutus
Kilroy
Post by Kilroy »
93forestpearl wrote:The only thing I would use that block for is serious sleeves, 14mm studs, a line bore and mod for a 257 crank.
Robot....rofl! :-D
The reason there are no Subarus left on the island is because all your buddies drove them to Alberta to get a job in the oil patch. :P :-D :P
Good luck with your build!
N1446
Post by N1446 »
yeah no kidding
i aim to eventually be headding west myself !
i hear the weather is Much more reliable !
as for the latest updates , they re only cosmetic and it looks as if it may be ready for the fall
The 2.5L install is covered in the Journal Post along with anything else releated to the EJ25 , this page is originally meant for the 2.34T build
.. fiberglass repair and pinstripe blackout complete
N1446 Brutus
Did you paint the chrome strips or tape them? Or rip them out I can't tell.
N1446
Post by N1446 »
it s a nasty effort , i peeled the chrome strip and it left a thick white double-sided adhesive layer behind ; i used brake fluid and a flat head screwdriver to soften the adhesive and scrape\maul\chissel it away
took like an hr
N1446 Brutus
I peeled the chrome from the back bumper because it was already coming off. I used electrical tape on the sides and front bumper but it's pretty difficult to get it on there perfectly and I think I'll eventually end up removing the rest of the chrome.
N1446
Post by N1446 »
yeah - not to mention its a weight reduction so it has to be faster now too
N1446 Brutus
