Need help with shift linkage
Kecksauce
Post by Kecksauce »
I'm sure some of you have had the issue of being able to "churn butter" with your shifter levers before, but mine has a stupid amount of play. I'm having a hard time finding parts, so I was hoping someone could point me in the right direction. I've torn into the car a bit, and this is what I found.
The bushing that the ball end of the shift lever sits in has a ton of slop in it. I was under the assumption it's pressed into that part of the linkage and cant be replaced, requiring you to replace that whole section of the linkage. Am I wrong?
Links and Ideas would be sweet!
-Keck-
-'06 Impreza 2.5i wagon
-'93 Legacy SS
PhyrraM
Post by PhyrraM »
What I decide to do was to get a low milage WRX take-off. The part between the "A"s in the diagram needs to be swapped for a WRX piece however.
If the part you circled is worn that means that the cup (under "C" in the drawing) is really gone. The cup is supposed to take the wear.
Kecksauce
Post by Kecksauce »
PhyrraM wrote:What I decide to do was to get a low milage WRX take-off. The part between the "A"s in the diagram needs to be swapped for a WRX piece however.
Yeah you're right. I knew somebody could explain it/picture it better haha.
So a complete wrx shift linkage would work then? That'd be sweet and make things easy.
-'93 Legacy SS
PhyrraM
Post by PhyrraM »
Yes a WRX shifter will fit, but you need EVERYTHING in the drawing. The front piece (between the "A"s) is hard to change while in the car, but some have managed to do it. I did mine at clutch time, so it was cake.
Check out page 1 or 2 in my build thread for pics.
Kecksauce
Post by Kecksauce »
Good deal. Thanks dude. Next step is trying to find the wrx linkage and a bushing kit! Any ideas where to look aside from a junk yard?
-'93 Legacy SS
skatedees
Post by skatedees »
Here are some threads that may help...... and if it were me, I would just buy new from factory. IMO it's not that expensive. Part numbers are in the links.
http://bbs.legacycentral.org/viewtopic. ... s&start=73
http://bbs.legacycentral.org/viewtopic.php?t=40266
1991 BJ EJ22
Kecksauce
Post by Kecksauce »
http://cgi.ebay.com/ebaymotors/02-wrx-i ... 1753wt_931
so I get to buy something like this and the adapter that connects the linkage to the tranny at the housing (aka "the piece between the A's").
Sweet. Thanks for the help guys!
-'93 Legacy SS
Post by entirelyturbo »
I'd be willing to bet money your plastic cup bushing is fine. It's well-lubricated and hidden from the elements. I've never seen one in need of replacement.
It's your A bushings that are worn out. They're exposed to the elements, and in most cases, have rotted away to where they're just plain gone.
Those threads skatedees posted will be a huge help to you.
*Formerly DerFahrer*
Kecksauce
Post by Kecksauce »
DerFahrer wrote:I'd be willing to bet money your plastic cup bushing is fine. It's well-lubricated and hidden from the elements. I've never seen one in need of replacement.
That's what I was initially thinking but after removing the shift boot, plate and the rubber seal to get a good look at that cup, I saw that there was a little play. Sucks because a simple bushing job is turning into replacing damn near everything
-'93 Legacy SS
Kecksauce
Post by Kecksauce »
::UPDATE::
I picked up a linkage assembly from a GC8 over the weekend for $5. I don't know if it's any different than a wrx linkage but for five bucks I couldn't pass it up. The cup is in way better shape than the one out of the legacy, but before I order new bushings I wanted to make sure it will work.
Insight?
-'93 Legacy SS
Kecksauce
Post by Kecksauce »
Bueller....Bueller...
Any takers?
-'93 Legacy SS
skatedees
Post by skatedees »
I'm not sure. I would compare and contrast the two. Take your old one out and see if it matches up.
Or look at the pics on the first link I posted and compare it to those photos.
That's all I got.
1991 BJ EJ22
It'll work. There's a slight difference in the width of the actual shifter. You can see what I mean in this pic
http://main.experiencetherave.com/subar ... P_3623.JPG
Kecksauce
Post by Kecksauce »
That pic is a HUGE help. Thanks dude!
Time to order all new bushings :)
-'93 Legacy SS
