Body & Suspension Parts, Gauges, Rims w/ R-Comps + more.
OK, I would need brackets, so NM.
Legacy Central
I'm on the coast of CT, about 30 miles from NY - note that my prices are for everything shipped. However, if you want to pick up I'll obviously offer a discount.Reiji Dorifuta wrote:Where do you live?
And, uhh, will the WRX fronts fit on 15" wheels?
And the WRX brakes will not fit any factory 15" wheels. They will fit some aftermarket 15" wheels, but in general, you need 16" wheels or bigger to run the WRX brake setup.
...but you're better off having these around for a rainy day than in a few months to find your brakes are going out , and then have to either try to get lucky and hunt another set of these down OR spend twice as much just replacing your worn OEM stuff with new OEM stuff with no real performance benefit.Reiji Dorifuta wrote:Right now I'm rocking steelies![]()
Damn, this might turn out to be a 'big miss' for me, 'cause I'm not the type who buys parts and lets them sit around for a rainy day...
Just my humble opinion.
