Forester Suspension on a BJ
NW_Legacy
Post by NW_Legacy »
I am newer to the forum and I have looked through many of the suspension threads and haven't really came up with a clear answer.
What do I need to swap in a Forester suspension into my girlfriends BJ?
I am looking to raise her car a little and heard this does. Plus her struts are on their last leg here.
I'm actually enjoying modding her BJ over my WRX at the moment because everything that is left to do is to expensive for my car :roll:
If anyone can give me a clear answer it would be greatly appreciated.
wtdash
Post by wtdash »
Here's a POSTto help and check out http://ultimatesubaru.org/forum.
Forester struts will give you a higher front than rear.
Here's a pic of MINE w/Forester FXT struts and 205-60R/16 tires, b4 i put on the WRX struts.
Go w/OB struts ('96-99) to get a more equal front/rear lift, IMHO. 205/75R-14 tires will fit and add another 1/2" of height. They're almost the same size as the stock OB/Forester 15'' tires.
The fronts will fit easily; the rear top hats will be needed from your BJ, as the top bolt pattern is different.
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
The big weave
Post by The big weave »
Also when you do outback struts you need to pay attention to camber.
92ss 5-speed winestone
92 Galant VR4 554/1000
And yes its rally ready
