20MM HUB CENTRIC SPACER ADAPTER
anyone have give a try to those kind of hub spacer?
http://cgi.ebay.ca/ws/eBayISAPI.dll?Vie ... gory=42614
i would like some feedback!
I have hubcentric 25mm wheel spacers
Mine are built by Eibach and they are a different design. Mine don't require longer studs. The spacer goes onto the hub and is bolted down with the included low profile lugnuts. The spacer itself then has lug bolts that your wheel is mounted on and you use your original lugnuts to secure the wheel.
Sorry yazmo, I don't have a picture at the moment to help explain.
One thing to be SURE of is you need to find out exactly what kind of aluminum is used. It is not enough that they say 'it is very strong'. They will always say that, and I doubt they have a warranty that will cover your car and your health if something happens.
I put my spacers on back in May, but with 17" wheels they just didn't fit so I took them off.
I plan to use them when I put my winter wheels on.
Andrew
16 Outback - wife's daily
95 Gravel Express - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
they are hubcentric
they came with the studs pressed in
they came with nuts that go on the hub studs
so you use your lugnuts to go on the spacer studs
so I didn't notice a difference based on the spacers
i just like wheels to fill out the wells.....
heh, today was the first time I used them, but... it was with different wheels and tires and in snowyazmo wrote:do you feel some handling improvement with these?
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
I had already rolled my fenders to get my 17x7s in there, but the rear passenger fender needed a tad more.... other three corners were fine
also remember that I am about an inch and a half lower than stock
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
Why do you have a baseball bat leaning against the car.......
I was wondering the same thing. A legacy...snow...intersection....basebal bat? WTF!
Then it made me think of this video which is pretty funny. There's a baseball bat at the end of the video.
http://www.youtube.com/watch?v=qh2Jed20wLk
You can roll fenders with a baseball bat?
I too would like to see a demo on the baseball bat method.
http://forums.nasioc.com/forums/showthr ... ?t=1777067
My opinion... take it to a shop that will do it, or rent a real roller and do it yourself.
91 SS with a bunch of parts waiting on the shelf
94 SS with things and such
08 STI with stuff and junk
http://www.youtube.com/watch?v=DDTK9IjKIYU
Skip to 5:00. That's how I did mine and it worked perfectly.
*update*
when I added a passenger there was rubbing on all four corners during any loading of the suspension
I will see if the body can be adjusted to accommodate, but I may need to take these off.
Andrew
92 Green SVX - RIP
02 WRB WRX - Sold
92 Green SVX - RIP
02 WRB WRX - Sold
