ej22 convert to dohc
calvin6199
i have a ej22 motor i am wanting to build should i go with a ej25 sohc head or dohc head also i am plaining on puting a turbo on it. I need to know what head gaskets to use and if the pistons have to be changed.Ii dont know much about the subaru's but have built several vw beetle motors i plain on putting this motor in my beetle too
Welcome to the board.
Please do some searching- all your questions are addressed on here.
Get educated and come back w/specific questions.
I Guarantee You it'll make the answers more meaningful w/a frame of reference.
Td
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
calvin6199
Did a little searching in these forums, I found this:
http://bbs.legacycentral.org/posting.ph ... e&p=274337
Also, the DOHC vs SOHC thread:
http://bbs.legacycentral.org/viewtopic. ... light=sohc
Basically what I got from that is the 2.5 SOHC and 2.5 DOHC heads are good for different reasons, but the 2.5 SOHC models are "phase II" heads, and the coolant passages don't line up with "phase I" blocks, and
Regarding your question about whether your phase 1 SOHC intake manifold would fit phase 2 SOHC heads, I would imagine they wouldn't but I haven't tried that combination. Let us know
in this forum:555BCTurbo wrote:Always use head gaskets that match the block
(from that same thread).93forestpearl wrote: The DOHC EJ25D heads use a phase I design and trigger signal, and flow better to boot.
Very quickly, because there is everything you need to know documented already.......
You cannot use your EJ22T intake manifold. You must use a manifold to match the heads you choose.
Phase 2 SOHC heads will not work with a stock up-pipe because they hit each other. The "corner" of factory turbo heads, and derivitives, is cut out for up-pipe clearance.
calvin6199
I have read a lot on this forum but I have a ej22e not the ej22t so there is not as much for it listed also I saw in one thread that the intakes for the phase 1 heads all interchange I did not relise the ej25 sohc head was phase 2. I am trying to get out the easiest way posible the dohc head swap seamed like I had to change more and like coolant line timing belt covers tensioners ect.
Thanks for the info I am still reading about it also
jdmleggy97
calvin6199
jdmleggy97
calvin6199
Also just remembered the heads on the ej22t are dual port and the ej22t are single port is there a big diferance in the flow. Can I put a turbo cams in my n/a heads
Aslo wanted to say thanks for all the info this forum realy knows what's going on. I have been on other sites and u ask a tech ? And they have no clue
Which ej22? The ones in the first gen legacy are dual port, just like the turbo heads.
Only the phase 2 ej22 has a single exhaust port per head.
calvin6199
Yes, the ej22 in the 98 impreza is a phase 2.
calvin6199
calvin6199
EJ22e
To clarify (hopefully JC will forgive me).
Phase II EJ22e started in 1999:
Per wikipediaand cars101.com.
- 1995 was last of the dual port exhaust EJ22e (and 1st year of OBDII for the Legacy)
- 1996 was the last year of the non-interference EJ22e; 1st year of the single-port.
- 1997-1998 EJ22e - interference and single-port, along w/internal and head upgrades (but still Phase 1).
- EJ22e Phase I = 1990-1998 for USA.1999 2.2 Liter Phase 2 Engine Enhancements (from endwrench article H-4 and H-6 service): All 2.2 liter engine for 1999 are the Phase 2 design. The 2.2 liter Phase 2 engines are a SOHC design, with a newly-designed cylinder head.....
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
calvin6199
jdmleggy97
Damn phase 1, phase 2 crap. I always hated referring to things like that....just like all version blah blah blah blah
calvin6199
That information refers only to DOHC heads. If the intake bolts line up on DOHC heads, they are phase 1.calvin6199 wrote:......was reading on this forum and thought i saw that if the intake bolt holes lined up it was a phase I is this true if so mine is not phase one
IIRC, all SOHC heads have offset intake bolt patterns. Phase 1 and phase 2 are both offset, but not compatable with each other.
calvin6199
