Dont' want to thread jack, but here's how we're doing it.
Well, Stat's fab work is primarily farmed out to me, and he's out of town for work so here's what I got done tonight.
We figured out that we could use the stock bosses in the Radiator where the condensor is supposed to bolt on to it. This ment adding some tabs to the core support to utilize those bosses.
To get the radiator to fit vertically in front of the support, I had to cut out the pinch weld and front section of the lower support
I had to cut the 3 lower grill mounts, and the inner most headlights off to get them to fit on. The bumper beam is going to need to be trimmed at the pinch weld to get the Rad sitting vertically as well.
The upper radiator hose is almost perfect! I mounted the rad just low enough to easily get the upper hose on.
On the inner side of the core support, we'll have to wrap the hose and trim a little metal so that the hoses doesn't rub.
That's all I got done tonight. I'm hoping tomorrow evening I can build the lower mounts and start trimming the bumper beam and the black plastic bumper beam as well.
