I am running the 550cc Sti injectors, which allow the good match for the vf39. I also have a ton of other mods, but those are mostly supporting and don't have much to do with the power output.
The dyno this was done on is comparable to the other shops in the mile high area.
I am super happy with this setup for the moment. The car feels pretty fast. I was making 240tq and 180hp with the td04 at 16psi, so it's a good increase for just the vf39.
This gives me some time to enjoy this power while I build my 2.35L stroker. I will be starting a build thread for that shortly.
macipusy wrote:I am running the 550cc Sti injectors, which allow the good match for the vf39. I also have a ton of other mods, but those are mostly supporting and don't have much to do with the power output.
This is exactly what I was questioning was comparing the td04 to the vf39 performance. I will definitely be looking into larger turbo upgrades and injectors for the future when revtronix releases a fully tuneable chip. ATM with the td04 on a auto i am pretty happy as the torque does a good job, if my car was stick would probably want the hp too. Actually I want the HP and torque no matter what
One thing to keep in mind for this setup is the intercooler. The 06 WRX TMIC I am running is too small with the vf39 at 17psi. It definitely heat soaks and it was evident. When we did 4 pulls on the dyno in a row, each pull lost between 5-10 hp. When we let the car cool off for 20-30 min, the next pull was always good.
I actually saw 280ftlbs and 245hp on one of the pulls, but the curve was more choppy, so we didn't print that one.
macipusy wrote:One thing to keep in mind for this setup is the intercooler. The 06 WRX TMIC I am running is too small with the vf39 at 17psi. It definitely heat soaks and it was evident. When we did 4 pulls on the dyno in a row, each pull lost between 5-10 hp. When we let the car cool off for 20-30 min, the next pull was always good.
I am now looking into running a FMIC.
I wonder how meth injection helps? Or a IC sprayer.
The tuning was done by Harvey, who owns his shop....The Boost Creep Ltd. He has been around for a long time in the Denver/Boulder area and is a very reputable tuner.
