Dyno tuned the 91 SS
macipusy
Post by macipusy »
I got my 91 SS dyno tuned by Harvey at The Boost Creep Ltd.
This is on a stock longblock with 230K and crappy 22t heads.
I'm running the vf39 with 550cc injectors at 17psi tuned with the pp6.
Made 270ftlbs and 240hp...the torque is expected but hp seems good for the heads.
maciek puszynski
16 WRX | 6mt | fa20
2.36L Turbo - RSTi Build
douglas vincent
Post by douglas vincent »
Nice!
smh0101
Post by smh0101 »
Wow... Those are some really good numbers!
Apex3
Post by Apex3 »
Very nice! So you just have a stock ej22t with a new turbo at 17psi? I'm just asking because that seems too good to me for that.
Those numbers seem reasonable. The 22T heads are capable of making some power. Just not as much as other options.
I was making around 300 with the 2871R and Delta cams.
That's awesome. Guys remember dyno results vary from dyno to dyno.
macipusy
Post by macipusy »
I am running the 550cc Sti injectors, which allow the good match for the vf39. I also have a ton of other mods, but those are mostly supporting and don't have much to do with the power output.
The dyno this was done on is comparable to the other shops in the mile high area.
I am super happy with this setup for the moment. The car feels pretty fast. I was making 240tq and 180hp with the td04 at 16psi, so it's a good increase for just the vf39.
This gives me some time to enjoy this power while I build my 2.35L stroker. I will be starting a build thread for that shortly.
maciek puszynski
16 WRX | 6mt | fa20
macipusy wrote:I am running the 550cc Sti injectors, which allow the good match for the vf39. I also have a ton of other mods, but those are mostly supporting and don't have much to do with the power output.
This is exactly what I was questioning was comparing the td04 to the vf39 performance. I will definitely be looking into larger turbo upgrades and injectors for the future when revtronix releases a fully tuneable chip. ATM with the td04 on a auto i am pretty happy as the torque does a good job, if my car was stick would probably want the hp too. Actually I want the HP and torque no matter what :D
macipusy
Post by macipusy »
One thing to keep in mind for this setup is the intercooler. The 06 WRX TMIC I am running is too small with the vf39 at 17psi. It definitely heat soaks and it was evident. When we did 4 pulls on the dyno in a row, each pull lost between 5-10 hp. When we let the car cool off for 20-30 min, the next pull was always good.
I actually saw 280ftlbs and 245hp on one of the pulls, but the curve was more choppy, so we didn't print that one.
I am now looking into running a FMIC.
maciek puszynski
16 WRX | 6mt | fa20
Mattheww044
Post by Mattheww044 »
wait, swapping from a td04 to a vf39 with the tune alone gained you 60hp and 30tq?
macipusy wrote:One thing to keep in mind for this setup is the intercooler. The 06 WRX TMIC I am running is too small with the vf39 at 17psi. It definitely heat soaks and it was evident. When we did 4 pulls on the dyno in a row, each pull lost between 5-10 hp. When we let the car cool off for 20-30 min, the next pull was always good.
I wonder how meth injection helps? Or a IC sprayer.
macipusy
Post by macipusy »
I did install a lightweight flywheel in between the td04 and vf39....so that might account for some to the wheels power increase.
The rest of the improvement is from the vf39 and re-tune.
maciek puszynski
16 WRX | 6mt | fa20
Mattheww044
holy crap, i just didn't expect THAT MUCH of a power increase over the TD04, is it a pretty agressive tune?
Mattheww044
also, im guessing thats AWHP?
Very nice numbers.
macipusy
Post by macipusy »
Yes this is AWHP....I am guessing that is around 350ftlbs/315hp at the crank
maciek puszynski
16 WRX | 6mt | fa20
asc_up
Post by asc_up »
Wow! Looks like it actually holds ~240 hp all the way to redline, too!
Very nice!
macipusy
Post by macipusy »
Feels like it pulls hard all the way now. Before, with the td04, it dropped off up high.
maciek puszynski
16 WRX | 6mt | fa20
asc_up
Post by asc_up »
Who did your tuning?
Imprezive
Post by Imprezive »
looks good! Ya the stock heads can yield good numbers. my car did 200whp 200ft/lbs on a dynojet @ 10psi w/ a 16g.
SOHC leggy heads ftw!
1988 4Runner RIP
2006 Suzuki DRZ400sm
2007 Miata
1994 Miata
2003 WRX Wagon
2016 Mazda 3
sqc151
Post by sqc151 »
thats awesome, nice numbers.
can u post ur full mod list.
im curious if certain parts were used in addition to the vf39, sti injectores, wrx tmic and ecu.
ie: exhaust, headers, catless, fuel pump, intake, stock or aftermarket clutch... etc. what other parts do u have?
im very impressed with these numbers thats why i ask... thanks.
macipusy
Post by macipusy »
Here is the full list of engine mods up to date:
Engine:
VF39 turbo
06 WRX TMIC
550cc STi fuel injectors
Walbro 255 fuel pump
92 Legacy NA fuel rails
Invidia bellmouth 3” DP
Borla 2.5” CBE
Coffee mug intake mod
JC Sports cone filter
TurboXS recirc BOV
NKG Iridium spark plugs
Diamond coilpack
8mm spark plug wires
Lightweight pulley set
Exedy lightweight flywheel
Group N tranny mount
Group N pitch stop
Hallman MBC
Manual FCD
PP6
IC sprayer nooozles
WRX Coolant Reservoir
maciek puszynski
16 WRX | 6mt | fa20
macipusy
Post by macipusy »
The tuning was done by Harvey, who owns his shop....The Boost Creep Ltd. He has been around for a long time in the Denver/Boulder area and is a very reputable tuner.
maciek puszynski
16 WRX | 6mt | fa20
sqc151
Post by sqc151 »
wow, really nice. so no major engine work whatsoever. why the change in fuel rails?
and i just clicked ur link. nice build u got goin there. good luck with it.
macipusy
Post by macipusy »
The 92-94 N/A fuel rails allow me to run the USDM STi 550cc injectors.
maciek puszynski
16 WRX | 6mt | fa20
