I have a quick question... apart from modifying intake plumbing, will the exhaust side of my '91 legacy turbo bolt up to a new wrx turbo (header, downpipe)?
Thanks,
Matt
2002 WRX Turbo -> 1991 Turbo Legacy
Kam
Yes - unless you have a downpipe which has a splitter, which separates the wastegate gases from the main turbine exhaust, like the MRT jobs. The length of the splitter may give you some probs depending on what turbo you're changing to.
Josh Colombo
Yeah I believe the exhaust side will work just fine.
Matthew Reese
Thanks for the confirmation. I was the winner of an ebay auction and purchased a 2002 wrx turbo for $172.50. I am currently rebuilding my 2.2 Turbo engine and didn't want to go with the stock turbo. I now need to squeeze a front mount intercoler in front somewhere....
Matt
Matt
INCEv@webtv.net
I would recommend the Water/Air top mount intercooler (more efficient).
Alot less hassle in the piping department. $0.02
Dan
Dan
ej22t_
I had a set of 02 WRX header and downpipe in my company and I found
out it won't fits to my 92 Legacy turbo since some bending a little
bit different and also sure the header won't fits on the car, so you
better make sure before you install to your car!!
Ben
Ben
Matthew Reese
Thanks I'll check it out. I think the bolt pattern is the same but the exhaust pipes themselves are not the right bend angles and lengths. I am only installing the turbo unit and will use my original up and downpipes.
Matt
Matt
