Not necessarily... To run a Link all you need to do is cut the wires from: the injectors, the coolant temp sensor, the ignitor, and the TPS connect them to the Link Wiring Harness... Then tap into the crank and cam sensor wiring and run it to the Link and lastly run a Vacuum Line to the Link.ericem wrote:
Im just saying IMO for our cars it is. As there is alot of work needed to run anything but stock EM with a chip. Obviously its not brutally fast, but a td04 is a td04 and its goes as fast as a td04 will![]()
If its not firing, its not firing! That's the problem, find out why it's not firing!! Of course your running on 3 cylinders if its not firing. Don't on to the other problems that could be. What wire from the ecu goes to the coil which is related to spark on cylinder 4? Trace it.
Done. Link G3 Installed and you can do a HELLUVA a lot more than the Revtronix Chip (Stage 2, the user-tunable on isnt out yet so doenst count because its not a viable option atm).
And a td0-FAIL is SLOOOOOOOOOOOWWWWWWWWWWWW
