It all started when i decided that the Legacy L wasn't really doing it for me... so i looked around and almost bought one of these...
Wow, it literally looked just like that.
The Corrado i was interested in needed some work *ahem...Understatement...ahem...coughCough*
so i found this lil' butte in town for a bit more expensive than the corrado, but i knew it would be reliable like the L.
i decided to get it b/c it has a turbo AND it's a wagon.
With this car, I'm able to drive around all my buds wherever we go AND put all of my life in it. Seriously, Picture of the car loaded to come.
I didn't want to sacrifice my lifestyle by purchasing a sedan.
Initially when i purchased the car there was alot of stuff wrong with it.
I had to fix/replace the drivers side:
*Headlight
*Corner light
*Fender
Plus, somehow the previous owner *cough.cough* tony *ahem..cough cough*... messed up some other stuff i had to pay for like..
4 new not-warped rotors
new pads
new calipers
I also had to replace the rear struts because they were destroyed,
I then purchased some brand, Spankin' OEM Struts for a good price.
Still need new Springs....
And replaced a leaking power steering line with Ferrari494's help.
This is a picture of the car after i finished all of the above...
*Oh yeah, and i "blacked-out" the headlights. without a doubt the coolest and cheapest mod out there.
This is how to do it:
1. Go and get some black spraypaint from somewhere (mine was $1 @ home depot)
2. Take your headlights off your car
3. let your oven warm up to 260*
4. Put the Headlights in (with the tabs off, you will burn your fingers bad if you arent careful)
5. Let em' sit for about 4 min. (checking if need be)
This will warm up the adhesive that holds the housing and plastic together
6. take em' out and take em' outside. using newspaper and masking tape, cover up the inner circle area WELL you dont want the inside of your light black. need the reflection..
7. Do to both and Spraypaint
8. let sit until satisfied.
9. repeat steps 3-5 then re-apply the tabs.
and you're golden
To finish off the basic "fixing" of the car, i had ALOT of the expensive and stupid ICE that came with the car removed/ wires cut.
Oh, and i bought Farrari494's STi exhaust for a steal
And it looked like this...
Then i drove to school and it snowed a bunch
Then my buddy was selling his 25rs scoop for a deal, because he was putting a 04 STi scoop on.
I thought, Hey that might be cool eh?
So i borrowed it to see if i liked the style..
and i decided, hell yes it looks sweet.
I started putting it on and ran into some trouble b/c i'm the only one that has done this that i know of...
My 2.5 RS Scoop Install Thread: http://bbs.legacycentral.org/viewtopic.php?t=34490
B4:
After
Then i decided JDM fogs were pretty cool, so BlackBart hooked me up
Then i realized that i didn't understand wires at all,
so with some help from the forums and my buddy I got it done.
and they're bright
Then i decided WTF was the point of JDM fog lights, without an Intercooler?
Found one in the shed and got it:
I figured out how to install the 06/07 TMIC with the stock coolant tank here:http://bbs.legacycentral.org/viewtopic.php?t=35056
Then i struggled a wee-bit installing it
*Read this for help with 06/07 TMIC install: http://bbs.legacycentral.org/viewtopic. ... sc&start=0
Here is some 06/07 TMIC w/ VF11 info:
my gallery: http://gallery.legacycentral.org/v/Memb ... +business/
You are going to need:
a 45* Mandrel Bent pipe that will fit inside your 90* silicon hose.
a silicon hose (90*) from siliconintakes.com that is both the outer diameter of the turbo outlet and the mandrel bent pipe you will be using. i think its 1.75. search it
you are going to need at least 6 hose clamps also, and some kind of hose to run your recirc/ blowoff whatever you want to do.
Got pissed about the install and bought Kumho Ecsta ASX's to make myself feel better, it worked
Got it in with silicone:
http://www.siliconeintakes.com<-- from here
YOU WILL WANT THE 1.75 one for thte VF11,
thanks NuclearBacon
And I installed Dscooby's old MBC with help from STipro, BXSS, and Subarujunkie.
And a Boost Gauge:
Then i received the RS decals from shtbxr22, so i put them on
and yesterday~ish i put the back one on like so..
Then i copied Smh0101 & asc_up:
And painted my wheels
B4:
After
i couldn't ask for anything better..except for this
But more realistically, this
Future Plans:
Spec B Wheels
KYB AGX + sleeves
TD05-16G/VF39 + the other necessary stuff
Big Down/ Up pipe
