We did some minor tweaking with the accel enrichment once I got to Houston, but overall it runs good, and I am pretty happy with the power.
On 91 octane it put down:
235.7 HP @ 5000 rpm
264.9 ft-lbs @ 4000 rpm
On 93 octane it put down:
242.4 HP @ 5000 rpm
280.2 ft-lbs @ 4000 rpm
Those numbers are wheel horsepower and torque. Stock STi puts down around 250 hp & torque to the wheels on their dyno.
You can see from the plots that the heads really are the limiting factor. But I can't complain too much as the motor is making nearly as much HP, and MORE torque than a DOHC head with much larger ports & valves.
As some of you may have noticed in the engine forum. I've got a thread about some cooling system issues. I think it's a head gasket, but will wait until I test the coolant for hydrocarbons. Surprisingly the engine runs fine. I just don't think the stock head gakset can hold up to 20 psi of boost. Plugs are good, so no real signs of bad detonation. If I have to pull the head gasket I will probably try and get the heads to flow a little more with p&p & cams (I'd be stupid not to...haha
![Razz :P](./images/smilies/icon_razz.gif)
Ok, onto the plots. (click on the image for a larger image)
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low1.jpg)
This plot shows the pre-tune and post tune on 91 octane
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low2.jpg)
This plot shows the 91 octane tune vs. the 93 octane tune
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low3.jpg)
This plot shows the 91 octane tune vs. a stock 2002 WRX (note the scale is off on the WRX plot)
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low4.jpg)
This plot shows the 91 octane tune vs. a mod. 2004 WRX (note the torque difference at mid-low rpm)
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low5.jpg)
This plot shows the 91 octane tune vs. a mod. 2005 WRX
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low6.jpg)
This plot shows the 91 octane tune vs. a stock 2006 WRX
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low7.jpg)
This plot shows the 91 octane tune vs. a mod. 2006 WRX w/ Tomei header & up-pipe
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low8.jpg)
This plot shows the 91 octane tune vs. a stock 2006 STi
![Image](http://main.experiencetherave.com/subaru/images/fli_dyno_plots/fli_dyno_low9.jpg)
This plot shows a final report of the pre-tuned 91, post-tuned 91, and post-tuned 93 runs.
All the plots can be found here
http://main.experiencetherave.com/subar ... yno_plots/
