A few Legacy parts
rally370
A few Legacy parts
Post by rally370 »
Steering universal joint $3 Diamond Coil $20 Ball joint $20 New
Some Phase I and II pistons $8 each. 2.2L bottom end complete $40 Phase I 2.5L bare block with good bores $15 2.2L intake $5 all plus shipping
Cheers
Chris
Rally Legacy AWD #370 gone! Rally Suzuki swift GTI N1 #370 parted out. Now Mini Cooper #370 with STI suspension in Costa Rica
skid542
Post by skid542 »
Just so I'm hearing this correctly, you are offering the Phase 1 bare block with good bores for $15 plus shipping?
If so, do you have a ball park estimate on shipping to 83836? I'm very interested :).
Lee
Yeah I'd take it for that much and I have no use for it lol. But shipping is gonna make it not worth it.
rally370
Post by rally370 »
The thing is I have several phase I blocks. Just each half of the block meaning no crank. I have some rods and pistons but not a full set. The crank/rod was bad. I was going to build the 2.5L block/2.2L heads but went with a phase II block. Then I thought about the 2.3L option but I bought the Suzuki rally car so all my efforts are going into this. The blocks seem good and it would be a crime to just junk them. So I figure someone can use them and I make a little towards my Suzuki rebuild. Checking with USPS I figure around $40 for shipping.
Cheers
Chris
skid542
Post by skid542 »
Chris,
Perfect! I'll send a PM over around lunch time or so to work out the details. But you may consider one of them gone. I've been wanting to build the 2.5/2.2 combo for my OBW for some time and this is a great/cheap way to do.
Or I may just slowly build a 2.5 for my SS. Eitherway, having a good block will be a good start.
Lee
rally370
Post by rally370 »
I have the 2.2 heads, some rods, Phase I and II pistons. PHase I give around 10.5.1 CR and Phase II 11.5.1 CR I have the Phase I in my Phase II block. I think I have all the block bolts etc. PM me and we can work it out. I'm off to Costa Rica this weekend so I could ship out before I leave.
Cheers
Chris
yazmo
Post by yazmo »
this is crazy how is the price for a rod when its new?
how about the block.
im interested nut ill pass this time since i wont do anything with this before a couple of time just hope i got some deal like this when the time come,
rally370
Post by rally370 »
here's some photos. I have a full set of Phase I pistons with rings and pins. A full set of Phase II pistons . No rings or pins. 3 Phase I rods. The block has all the bolts and is honed. I see a few slight scuffs but nothing serious. If you look at the block in front you can see the little marks. other than that the bores look good. The engines are ex CA dune buggy which spin bearings on a regular basis due to oil starvation on the dunes. The block I have in the Legacy is a dune buggy block. I was told these engines were brand new from Subaru???
Image Image Image Image Image
Cheers
Chris
biggreen96
Post by biggreen96 »
I'll take a ball joint for 20.
shoot me a pm with a paypal and total :D
rally370
Post by rally370 »
One block is sold with the rods and Phase I pistons.
Cheers
Chris
thatswhatshesaid
Post by thatswhatshesaid »
I'll probably take the 2.2 bottom end (non-turbo, I'm assuming...) if shipping to 99009 isn't too bad...
I WANT TO BUY A SS! PM ME IF YOU'VE GOT ONE TO SELL ME!
* '84 CJ-7, and a driveway full of Subarus... *
rally370
Post by rally370 »
The 2.2L bottom end wieghs more then USPS will take. Via UPS I would figure arond $90 to most places. I going to check the weight tomorrow. I think it must at least 90LBS.
Cheers
Chris
rally370
Post by rally370 »
I have left the coil $15 the steering uni joint, 2.2L bottom end which weighs a hefty 86LBS , 2.5L Phase I block , 1 set Phase II pistons no rings or pins $20. 2.2L non roller rocker type cams $15 the pair(good as core cams for Delta cam regrind?) 2.2L cam wheels $3 each, 2.2L head less cam/rockers $10 2.2L intake $5 2.2L standard header and cat $10 cheap prices but stuff that is just sitting there doing nowt......all funds go to the Suzuki rally car build.
I still have the Rally Legacy.....Never giving that up!
Cheers
Chris
HandleWitCare
Post by HandleWitCare »
Can i get a pic of the 2.2 intake? if its what i need i ll pick it up how much shipped to 63385?
rally370
Post by rally370 »
sorry I'm in Costa Rica. It is the standard 2.2L intake. If you can wait 2 weeks I can get a photo. I'll check the shipping and let you know.
Cheers
Chris
rally370
Post by rally370 »
Using USPS online the cost seems to be around $15 Let me know and I can ship it when I get back.
Cheers
Chris
rally370
Post by rally370 »
I found another set of pins for the Phase II pistons. Price is the same.
Cheers
Chris
I shipped block halves via Greyhound for pretty cheap. The two block halves don't weigh much (~40 lbs.? I could carry them easily)—it's the size of the package that hurts (that's what she said!).
yazmo
Post by yazmo »
anyone can tell me what the difference between phase 1 and phase 2?
rally370
Post by rally370 »
The Phase I has smaller crank bearings and a center thrust bearing position the same as the EJ22 in the center. The Phase II has the thrust bearing at the end and different size crank bearings.
Yeah I've figured spliting the block is cheaper to ship.....Not always is "big is better"
Cheers
Chris
biggreen96
Got the balljoint thank you Chris.
skid542
Post by skid542 »
^^^ I got the first installment of my new phase 1 short block the other day. Everything looks great Chris. Looking forward to getting the block :).
Lee
97gtguy
Post by 97gtguy »
interested in the 2.2l block shipped to 22193....lemme know.
Claiming victims 1 car at a time.
rally370
Post by rally370 »
Glad everyone got there parts OK. Problem is the 2.2L weighs around 85lbs so USPS won't ship. I figure UPS and FEdEx will be expensive. I'm going to check Greyhound.
Cheers
Chris
rally370
Post by rally370 »
With Grey hound I have to drop it off at the Boston depot and you pick it up at CharlottesVille for about $85 which makes it an expensive bottom end.
Cheers
Chris
