I'm not sure which one is better. One set has hydraulic lifters and one set has hydraulic lash adjusters.
http://forums.nasioc.com/forums/showthr ... ight=Ej20G
Does anyone know what the differences with these heads as far as the valves and combustion chamber size would be? There are so many variations of the EJ20G it's hard to keep track of.
Which set of EJ20G heads do I choose?
GodSquadMandrake
-Doug Wilson
douglas vincent
Go with the red valve cover ones! EASY to install, AND YOU WON'T LOSE ANY PARTSSSSSSS!!!!!! I have a set of the rocker arm ones that are worthless because I am misisng 1 part....
GodSquadMandrake
