92-94 sidemarkers on 90-91
Is this a fesiable idea? meaning can I just take the little piece of trim from a 92-94 with the sidemarker lights and put it straight on my 90? Or is there a difference in measurements? The area seems the same but you never know with year changes.
Rio Red 90 Legacy LS AWD 174k
Liquid Silver 92 SVX LS-L 88k
- quasi-mod-o
I'm thinking either splicing it into the parking lights or into the turn signals
yeah it can be done....
Yeah, you can swap the trim and put the lights in.
As for wiring it, I recommend connecting one wire to the switched side of the turn signal and one wire to the switched side of the parking light. That way, the sidemarker will function as both a parking light and a turn signal.
I highly recommend this mod to anyone with a 90-91 Legacy! It will make your turn signal visible from the side. Also, put a W5W (also called 2825) bulb in it instead of the stock 194. The W5W is brighter than the 194.
cool stuff i'm gunna go look for the stuff right away
