Zach's Legacy FrankenSTIn TW
Re: Zach's ABM 94 TW of Doom (
I Called AEM today and they want me to check and see if i can manually trigger the outputs (coils).
i will try this and post up my findings but im afraid that i may have to sent the box into AEM for their testing and diagnosis .
Brydon, I could definitley try that. the guy at AEM today that i talked to recommended that i do all the hardware testing before i do map testing/verification. I got more stuff in my binder i will add in here in a bit and i will respond to your email.
http://forum.aempower.com/forum/index.p ... 912.0.html
SOOOOOO update:
i got in touch w AEM this week and my tuner, and a local wiring pro named Bryant that had alot to say about the situation, and he evidently knew someone that knows about my specific AEM board and they basically said i should send it back to them to have it checked out. ..
before i send it off i decided to tear it open (since its not under warranty...etc) these are the results:
so looking at the image above you can clearly see that this stuff is not connected and got shorted out or something somehow... most likely from black car incident ...
So my options are to go ghetto an solder it back together and see if it works or send it to AEM, and im definitely going to send it to AEM. the corrosion seems to be in the same spot as where the outputs on the AEM are for sending signal to the coils for cylinder 2 and 4 ... oddly enough. so basically i am thinking that i drove back from Oregon on 2/3 cylinders and tuned the car on 2 because of this business.
at least i have finally isolated the problem and learned a ton in the process... now all thats left is to send the box to AEM and see what they say regarding the issue, and HOPEFULLY HOPEFULLY HOPEFULLY that its a simple fix and not.. well it should be obvious.
thoughts....?
thoughts....?
Glad you figured it out. Must have been a lot of unneeded frustration.
Kimo, yeah alot of sadness. just to add to all that i can't easily run an OEM wrx ECU in the car at all because of sensor bizness... which was going to be the fallback but yeah.. im sending the unit off today to AEM to look at so they can say "ß♫◄ZOMFGWTFFF♫Σα"
what helped more than anything is my friends that said "if you part ill be at your door with a mustache and disguise" hahaha
SSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSPARK ON ALL FOUR AAAAAAAAAAHHHHHH!!!!!!!!!!
LOL
Good to hear man!
Good to hear man!
hahaha yay!!!!!! How does it feel firing 4 holes? :D
I haven't driven it yet, I'm waiting for a corrected map from my tuner because it idles at 10 afrs which is way rich.
It sounds soooo swEet. Black car never sounded like this and after getting this car back it never sounded like this either.
I can't wait!
I can't wait!
Fuck yes! What was the problem?
The (main) problems were:
1. The corroded pin inside the AEM (see pic above) that killed the actual ground for the aem... which affected both the timing and the spark signal that was sent to the coilpacks.
2. THE COILS FOR CYLINDER 2 AND 4 WERE REVERSED!?!?!?!? This was done by the person that swapped everything from black to new car, and was overlooked by myself until recently when we thought about it. Ridiculous right? so essentially the computer was sending spark signal from to cylinder 2 that was actually hitting cyl 4... and signal for cyl 4 was going to cylinder 2.
Props to everyone that helped me with this, you know who you are and I'm grateful for your assistance.
video/pix/more to come after i update the firmware to .19 again tonight and verify the new map from my tuner tonight.
I'll have a new soob very soon!
the list
Playing with the AEM
The car drives awesome, it sounds totally different than the other ones and accelerates like a dream!
i will get video up eventually.
next on the list:
-fix rear exhaust tip somehow DONE
-paint drivers side fender ABM DONE
-get wiring stuff figured out so that the computer and gauge know the AFRs Done
-continue to tune the map on it, update to .19 firmware June 13th!!
-raise coils in the back a little bit
-get an N/A hood and paint it ABM
-re tint windows
-put on sideskirts + mudflaps DONE
-black out all side moldings DONE
-get boost control figured out so we can tune it for boost!
- Paint Wheels DONE!!!!
- Wire in JDM Foglights DONE!
- Wire Fans to always be on with ignition DONE!DONE!
-Knock Sensor wired in
- Put on legit exhaust hangers Very soon!!
- Build boost Leak Tester Very soon!!
Boost leak tester!
next on the list:
-re tint windows
Boost leak tester!
Last edited by SubaruNation on Tue Jun 01, 2010 2:09 am, edited 10 times in total.
Awesome Zach...
With that front mount... Your car has a soul patch LOL
Exhaust tip is now circular again! woo!
Spencer will appreciate this at least hahaha
Lol... Now just paint that damn fender.
I primerd it so its not white anymore.
I'm most likely going to do it after I decide to roll with a N/A hood and paint that or fix my hood scoop setup so that its
Mad flush with the hood and then paint that too.
What's wrong with the tint?
Tint is blackity black but for some reason peeling a little bit... you cant tell unless you get decently close to it but it bothers me.
Blacked out trim.
made something fun.....
That's hot! Care to enlighten us on the process?
basically sanding alot of a regular SS legacy grill and cutting all the center pieces off of it, then putting the mesh of your choice behind it.
I spray painted mine Midnight Black Metallic all over then put the Legacy emblem in the center for added awesomeness
Very cool!
I just want to say, I highly admire your work. Great car, looks stellar!
Also I'm very jealous! Lol.
I may ask you some questions about your setup when I finally get a Legacy! Lol.
hey thanks alot,90rwd wrote:I just want to say, I highly admire your work. Great car, looks stellar!
feel free to PM me if you have any questions.
I have a ton of How-to guides on page 1
more visual stuff completed, although im going to wait awhile on photos
in the meantime i'm all over this list above...
