And it's still down, I put the engine back together and back into the car. Finished about 9pm with the temp around 10 above zero. Loaded the battery and it sounds like the timing is quite a bit off. Disconnected the timing computer thinking that might be the problem and it still ran like crap.
So next step is to go back and remove the radiator and check the timing again hopefully it just slipped before i put it in the car and I didn't catch it. It'll probably be this weekend though before I get to it, too many exams this week.
Ru's build
Re: Ru's build
Well, the subaru is all fixed up and it's powerful. I put some new heads on it. But it's been sitting for the last couple of months as its been replaced by my new daily driver. I'll probably tune the suby and run it at the track this year hopefully.
///M
'93 Legacy SS - part out
