Ru's build
dzx
Ru's build
Post by dzx »
Engine:
CP pistons 8.5:1 compression
eagle rods
acl race bearings
2.5 dohc heads
2000ish legacy intake manifold
550 cc injectors
perrin pulley
Front mount intercooler
power steering, AC and ABS removed
Garrett t3/t4 50 trim turbo
Exhaust:
3" stainless steel TBE
external wastegate with external dump
Drivetrain:
4.11 manual transmission
sti short throw shifter
fidanza flywheel
ACT sprung ceramic clutch
Suspension:
front strut tower bar
Tein S-tech springs
WRX struts
Electronics:
Fuel cut defencer
plug and play Apex'i safc II
misc:
autometer cobalt wideband, oil pressure and boost gauge
indiglo dash gauges
greddy bov
electrical tape over the turbo awd badge on the back
I decided to change out the sohc turbo heads for the 2.5L dohc so I ordered some CP pistons made for 8.5:1 compression with the matchup.
Then i had to go through the heads and reshim them.
The intake manifold has 550 top feed injectors from an RX7
One of my friends was nice enough to come over and pull the old engine and transmission out for me cause I'm not strong enough.
///M
'93 Legacy SS - part out
Nice valve cover and intake manifold. Your friend is stronger than she looks. :lol:
I think I like the silver valve cover look. Might try it myself. What kind of paint did you use? I think maybe a gunmetal darker silver paint would be even cooler!
Fkyx
Post by Fkyx »
I'm pretty sure that's what color the valve covers are.
I don't think so. Mine don't look like that. They look like aluminum. Those look painted, recently. The intake manifold looks painted too.
dzx
Post by dzx »
They're painted and its a charcoal color but i'll look up the name next time i'm home.
here are some pics of the turbo rebuild. Need to drill some broken bolts out of the exhaust housing. The surclips that hold the bushings inside were a real pain in the butt to take out and put back in.
///M
It should be a ripper when done.
CP will be my next pistons. They are bomb proof.
Kelly
Post by Kelly »
Ya, I think I'd definately test her for steroid usage.
dzx
Post by dzx »
it's a metallic texture paint it didn't have an exact name on it.
///M
dzx
Post by dzx »
Well I was in Europe for the last month and a half so progress on the car was slow. I finished rebuilding the turbo and fabricating parts to make everything work. Today I put the turbo on the engine and the engine in the car...first go it cranked for a while but wouldnt start. Switched the plug wires around and it started right up.
So I need to switch the wires going to the coilpack, i figured they might have been backwards when i hooked them up. It's also running slightly bumpy and when i uplug the front driverside cylinder it shows no difference so I think one of my injectors went bad. I may have some replacements on the way though. I'll post pics when I get more time.
///M
dzx
Post by dzx »
///M
Airgne
Post by Airgne »
nice build. hopefully she i more than a freind because mmmmmmmmm asian!!!
1997 Nissan Laurel ClubS25t
1992 Legacy SS(Sold)
smh0101
Post by smh0101 »
Did you do away with your Power Steering? :smt104
Airgne wrote:nice build. hopefully she i more than a freind because mmmmmmmmm asian!!!
:lol:
dzx
Post by dzx »
I did do away with the power steering and the a/c a couple years ago. I like it better that way although there are some days i wish i had cool air.
The car runs like a champ now, for the first time in a long time, there's no oil drops anywhere and no smoke of anykind. The pistons are audible on startup but quiet down after a while. Now to finish the break in period for the turbo and the engine and then start tuning it for higher boost.
///M
dzx
Post by dzx »
It's really hard to keep my foot off the gas, I found some boost leaks and fixed them and the car moves pretty quick at 8psi.
The engine doesn't sound as beefy without the delta camshafts, it's more even and business like. I think it quieted the exhaust a little as well.
I don't imagine the transmission will last long once the engine is broken in so I guess i'll be looking for a replacement before too long.
///M
dzx
Post by dzx »
Well it ran well for a couple of months, extremely well at 20psi. Then I was driving along on the interstate and an intake valve snapped. No discoloration from heat, just a mechanical failure. Smashed the hell out of the head but luckily the piston shoved it sideways back into the valve hole. The cylinder walls aren't too bad. The CP piston has a little damage but overall not too bad. The spark plug looks like a banana. I'll post pics soon.
///M
mexicanzero
Post by mexicanzero »
that sucks!! i could only imagine 20 psi out of an engine like that...
hows the steering? are you using a different rack or just drained all the fluid out of the stocker? i'd imagine its not bad in motion but parallel parking and slow maneuvers must suck...
good luck rebuilding!
-Alex
LIVE LOUD, ROCK HARD!!@
1992 Subaru Legacy SS 06 WRX TMIC TD-04 MSD coil 3" turboback H&R coils GR2 shocks fsb 20mm rsb 22mm stage 2 chip
2003 silver wrx wagon 5 spd just bought!! stock for now...
Bummer. I hope it goes back together nicely for ya.
cartwheels
Post by cartwheels »
Get your friend to help again, haha.
1994 Legacy TW
1991 Legacy SS
1990 VW Vanagon Westfalia
Airgne
Post by Airgne »
damn that sucks. yeah get the asian to help again. they are great at everything.
dzx
Post by dzx »
It was 18 degrees at my house yesterday, she hung around inside by the fire and wouldn't come out once we got there.
I ground down any sharp edges on the piston, measured out the shims for a spare head i had and put it back together, so hopefully it will be back in the car by this evening although its another cold day.
Some new toys I got for the inside since some of the stock speakers are blown
And infinity perfect 6.1's
///M
dzx
Post by dzx »
The steering without power steering is ok, you can feel the road a lot better. It's been that way for about 3 years so i've gotten used to it. Parallel parking is still good excercise though.
///M
Nice call on the components. I've always been a fan of Infinity's Perfect line.
Airgne
Post by Airgne »
nice speakers.
