Lifter help
letsridestreet
Lifter help
Hey guys so i recently just rebuilt a ej22t and got it in the car started up fine and ran well. Lifters were really loud for about 20mins before they got pumped up. But then it seemed like i still had one or two stuck so i pulled the motor all the way back out and put it back on the engine stand and pulled the rocker arms off and i have 2 stuck ones. One on each side does anyone have any ideas on how to get these things on stuck.
1993 Turbo legacy wagon. (elboostio) $600
(Anyone can turn a wrench, but how well does he turn that wrench)
Re: Lifter help
You really didn't need to pull the motor again just to do the lifters. However, what I would suggest is bleeding the lifters again, and then reinstall. The lifters should be firm and not squishy once they've been bled. If you have squishy lifters after you bled them, then you need to replace those.
Re: Lifter help
is there a post here where its show how to remove the lifter?
i would like to bleed thembcuz i hear tic tic sond all day long.
i search around without finding anything. i read this cuold be HLA?
what is HLA lol where its locate at!!
same for the lifter....
in the hayne book its say only 1994 or later have lifter?
fishbone79
Re: Lifter help
HLA = Hydraulic Lash Adjuster. Those are the lifters on our car. Once you have the rocker arms off, _gently_ tug the HLA's out of their spots with a pair of pliers. Most of them will pop right out. The bleed procedure is in the FSM, but basically submerse them in oil, depress the ball valve and bleed out the air, let it suck oil in the other end, repeat. You don't want them squishy at all when you're done.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
Re: Lifter help
ok i found found the rocker arm assembly in haynes book
so this is consist of 3 bolt for the front panel and another 8 bolt what about the two knock pin ?
is there any precaution i should take i really dont want to brea anything
is there a gasket too? if there is any anyone have part number
and how many lifter the 2.2 engine as?
i try searching but i dint find anything about it
peace
peace
Re: Lifter help
I find it so weird that so many people have issues with hla's.When i rebuilt my engine i had meant to bleed them before assembly and had actually pumped all the oil out of them and soaked them in PB in preparation.Long story short i forgot to do it and started my engine with them dry,never heard a noise and never have since.
Re: Lifter help
Yeah I don't know....I've never really had any issues with them either.
