It seems like I blew my transmission out of my 92 legacy turbo wagon in a tsd rally yesterday, so I am wondering if there are any other suabarus that use the same tranny as mine (92 legacy 2.2 turbo auto)
It seems like the turbo cars are kind of rare around here so it might be difficult to find one out of a legacy and a re-built one from a shop is way more than the damn car is worth
Any help would be appreciated
Cheers
Kev
92 Turbo with a Blown Transmission
Re: 92 Turbo with a Blown Transmission
The 91-94 turbo legacy transmissions should all be a direct plug and play. The 92-94 non-turbo AT's also had a 3.9 final drive ratio, so they should work. You may need to swap the TCU, but if you go that route, I'd probably try the turbo legacy TCU.
Does anyone know any places to pick these up?
Where are you located?
Try calling these junk yards
http://www.aaronsautowrecking.com/
http://www.4subarusuzukikiaparts.com/
http://www.superrupair.com/
I'm in Calgary Canada. I have been looking around at the wreckers here, but the turbo version of my car seems kind of rare around here for some reason
Does anyone know if a transmission out of a 99 2.2 legacy would work?
I believe that is a phase 2 4EAT and probably will not be a direct swap.
