at next i want to drive @ the dyno to look @ the power.
You've validated the engine has enough fuel with a wideband I hope and datalogging. Otherwise, your injectors are very likely static while WOT and likely AFR is very lean.legT91 wrote:i can put the boost to 1,3 bar, no problems with the original injectors
BSOD2600 wrote:You've validated the engine has enough fuel with a wideband I hope and datalogging. Otherwise, your injectors are very likely static while WOT and likely AFR is very lean.legT91 wrote:i can put the boost to 1,3 bar, no problems with the original injectors
I know from my own personal wideband and data logging that TD05H-16G with stock injectors at stock boost of ~8 PSI maxes them out in the mid-rpm range...
