ARP Studs
ARP Studs
Was just curious if these look like the right ARP studs. I guess I had not seen ones that are chromed, so just wanted to make sure.
http://www.main.experiencetherave.com/s ... adwork/09/
Re: ARP Studs
Yeah, they look like both of my sets did.
Re: ARP Studs
Ok, thanks!
PhyrraM
Re: ARP Studs
Post by PhyrraM »
Same here. Looks like mine did.
Re: ARP Studs
Mine were chrome too.
Re: ARP Studs
Thanks guys
Re: ARP Studs
I don't think they are chrome. They just have a nice surface finish which makes them stronger.
The reason I say that is because the tops rust fairly easily in MN winters when used on the old single cam heads. The rust cleaned off easily, but there was no evidence of chrome with how the tops of the stud corroded.
Re: ARP Studs
You're probably right Dan.
IronMonkeyL255
Re: ARP Studs
Post by IronMonkeyL255 »
At least they sent you the right studs to begin with.......
Rio Red '91 Legacy SS
Re: ARP Studs
Well.....I ordered those studs via part #, specifically based off of the information here (your thread). I did not tell them what application I was planning to use them for.
Re: ARP Studs
Quick question on the studs. Should the studs be bottomed out, or just unscrewed slightly from the bottom?
Working on getting the bung for the oil temp sensor welded into the oil pan this week, and should be ready to put the motor together....hopefully.
Re: ARP Studs
I thought they said bottomed out, finger tight.
IronMonkeyL255
Re: ARP Studs
Just barely hitting bottom. Basically, i stop once they stop turning, and usually back off a slight bit (like, an eighth of a turn or so) That way, you have full thread engagement on both ends, and have 3-4 threads sticking out the top once it is all said and done.
Re: ARP Studs
^That's what I did too, no problems so far (knocks on wood).
Re: ARP Studs
Thanks guys!
IronMonkeyL255
Re: ARP Studs
Only problems i had doing it that way were from using the wrong studs at first. When i used the short ones, it stretched the threads in the middle holes on both sides, so they were kinda tight running in.
