which 5mt
__TT__
which 5mt
Post by __TT__ »
well froze up the turbo tranny in the turbo wagon. So I guess time for replacement. Question is what to replace with. 2.5 rs tranny , wrx tranny, sti tranny, thailand tranny?
What is the most cost effective and reliable. I read a lot of infi that the wrx is a weaker tranny than our turbos!?
94 tleggy wagon, 22t with 2.5 dohc heads, pp6, tdo4, fmic, 3inch catless bpm turbo back, wrx brakes, MANY interior mods to list
Re: which 5mt
I vote STI 6spd but it's certainly not cost effective.
__TT__
Re: which 5mt
Post by __TT__ »
on another note. if I choose to crack open this whore, how is availiblilty for parts for the stock mt?
fishbone79
Re: which 5mt
Post by fishbone79 »
You can get most things you'd need. If you want to replace synchros, you might have difficulty finding the originals - they updated the design.
If you're ambitious enough to crack into one, I would highly recommend begging/borrowing/stealing the special alignment tools. It can be done without them, but they make it much easier. The fore-aft positioner for the pinion shaft was particularly useful, it took allot of the guesswork out of shimming to get the correct differential lash (which must be done through the sump hole while assembled and torqued).
Cheers,
morgan
1992 Legacy BF
__TT__
Re: which 5mt
Post by __TT__ »
Where would I find said alignment tools.
