want to buy a good 5 speed from a 98 and older awd.
it needs to have 2 things,
one the older style tail housing that has the removable inspection cover
and two must have the 2 drilled and tapped clutch fork pivot points inside the bell housing. i want to say these started around 93, 94, 95 range.
would like a driver, no noises, no grinds, nothing weird.
final ratio doesn't matter, 3.90 or 4.11 will work.
mellow65 is online now Report Post Edit/Delete Message
WTB 98 and older AWD 5 speed
fishbone79
Re: WTB 98 and older AWD 5 speed
I've got one, but I'm on the east coast. It's out of a 98 outback, runs fine. Slight diff whine on deceleration, it just needs a lash adjustment via the side bearings.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
i dont even know what that would cost to ship to the west coast. zips 97266, i might check with greyhound and see what it would run to ship. what are you looking to get?
fishbone79
I'll take $200 for it, but shipping is a bit cost prohibitive... I think it's too heavy for GH, so freight may be the only answer. I have pallet service at work, so it would be significantly cheaper, but still no less than $150.
Mileage is ~102k, BTW.
Cheers,
morgan
1992 Legacy BF
morgan
1992 Legacy BF
yeah i think im going to pass. would like to find something closer
