A Good Friend's Subaru (9's?) ........
'99 Impreza RS Coupe with ton's o' Stuff. 257, full bottom with CP's, etc, 1600cc injectors, Hydra, Aeromotive Eliminator, Corn, blah blah blah. BorgWarner S366 mounted in the foglight area. Twinscroll manifold from Fobiawrx. Fully built 4EAT from Derek (Whitelegacyguy).
The car makes 450whp and 600 lb-ft of torque. The turbine housing is small, thus the high torque and low hp readings. No dyno plots yet, but we have a pretty sweet video taken by Derek.
The shop owner and guy who tuned the car thinks it is capable of 9's, since it will wax his Evo 8 capable of 10's. It should be fun to see him booted off the track first run without a cage, lol.
http://www.youtube.com/watch?v=k2TX_g5M ... r_embedded
07Evolved
Re: A Good Friend's Subaru (9's?) ........
Post by 07Evolved »
wow...sounds like a jet taking off!
i would love to know what that runs.
Brad
1991 Subaru Legacy L AWD Wagon 5MT (DD)
2000 Outback 5MT (DD)
2005 AW STi
2010 LGT (hers)
1998 Outback (her DD)
Build Thread
TonyAWD
Post by TonyAWD »
My god...
if only my wagon could do that. So stoked to know how quick it is.
94' Legacy L Wagon
~96xxx miles
~ISC Coilovers
~Whiteline RSB, Endlinks, HD RSB Mounts
~Rallitek FSB
~02 WRX Wheels
~DIY Interior (In Progress)
familydad
Post by familydad »
holy hell, cant wait to TT mine
Hot damm that was fun!
1999 Legacy L postal, RHD
That is a sick car. 9 second subaru. Those are pretty rare.
sqc151
Post by sqc151 »
impreza: pulling into position, over
flight tower: roger, weve got u on radar
impreza: lining up for take off, over
flight tower: roger, your clear for take off
impreza: starting after burner, over
flight tower: roger that, we can hear from it here
impreza: OOOOMMMMGGGGGG!!!!!!!
flight tower: roger that, ur off the grid
Very nice!
LOL dyno plot.
He really could use a larger turbine housing. His torque converter might not be loose enough to make boost on the line quick enough though.Image
That awesome! How long can the tranny last though ?
Probably a long time since it's been built.
ericem wrote:That awesome! How long can the tranny last though ?
The auto is a Phase 1 4EAT that has been highly modified for drag racing. Among a ton of other things, it has a full manual, reverse pattern, trans-brake valve body. The only electrical components in the transmission control the 4WD and the trans-brake.
It will handle 1000whp without issue. Rigoli runs 7's on a closely related setup.
