Anybody selling a revtronix stage 2 chip?
Mattheww044
Post by Mattheww044 »
If anyone has a stage 2 revtronix chip and is going a different route with engine management, id be willing to pay $300 for one.
I need one that is meant for a Td04 with 440cc injectors. Thanks
jrsleeper
Re: Anybody selling a revtronix stage 2 chip?
Post by jrsleeper »
pm sent
97 outback
91 SS 5spd w/4.11's, vlsd, tdo4, 06 tmic, FCD, MBC, coolingmist water/meth injection, wrx eibach prostreet coilovers, wrx Kartboy STS
Mattheww044
bump
Mattheww044
to the top
gijonas
Post by gijonas »
I have just what you need...when i get off my ass and get another option together it will be for sale....hmmm.
Mattheww044
pm sent
amoore131
Post by amoore131 »
Mattheww044
they are out of business..... are they still shipping them out?
amoore131
Post by amoore131 »
The site seemed active so I would assume so and I could add to cart but you would have to get to the checkout and find out I guess
Off topic question but if you go with these mods (td04 440cc etc) and chip would you need the wrx fuel pump to match up with the injectors or no?
Mattheww044
ummmm, im not sure if you would NEED it, but I would HIGHLY recommend a walbro 255. I payed $100 from TRE Performance. Thats the best deal I found, and that should be able to supply all the fuel you need, unless if you go all out crazy, but the walbro is a damn good start, especially at that price. I sent an email to the Revtronix site or w/e so i will see what they say.
amoore131
Post by amoore131 »
Well shouldn't a wrx fuel pump for wrx turbo and injectors suffice? Wrx fuel pumps are even cheaper
On another note let me know how the contact goes
Mattheww044
well i would imagine the WRX pump will do just fine, but might as well get an sti pump or walbro, that way you won't need to upgrade the same part again
amoore131
Post by amoore131 »
Would that create some sort of overkill for fuel or would the chip account for the bigger pump? not really sure how that would go considering the site didnt say anything about upgrading a fuel pump
Mattheww044
no it wouldn't flood the engine or anything. It just has the capability of pushing 255lph, it doesnt actually just push it right off the bat. The injector size is what really determines how much your getting from how I understand it. say you just threw 800cc injectors on your car, that would not be good, but the walbro 255 would be fine with your stock injectors or 800cc injectors (considering you had all the supporrting mods & tune). But when dealing with upgrading your car and trying to make it faster, fuel delivery is a very important aspect
amoore131
Post by amoore131 »
so running 440cc injectors and the chip would account how much fuel is needed no matter how big the pump is? My buddy said I would need a fuel pressure regulator so it could be adjusted
Mattheww044
From what I understand, if you have 440cc injectors, and the other required mods for the stage 2 chip, the chip somewhat "tunes" the car to compensate for the extra air and fuel. I don't believe you need a fuel pressure regulator, it doesnt say anything about it on the site. Actually I think we have one stock, but I really don't know anything about them so I'm not sure how that comes into play
amoore131
Post by amoore131 »
Okay so I read up a little bit on the site and from what I collected the MAF will send info to the chip/ecu on how much fuel is needed for the correct air to fuel mix sooo... I guess it won't matter how big the fuel pump is, but I assume at least a wrx fuel pump is needed without getting fuel cut with the stock one
Mattheww044
well the chip actually acts as a fuel cut defender as well. I wouldn't do the stage 2 upgrade without a bigger fuel pump n my car, but thats just me. $100 is well worth knowing your getting all the fuel you need in my eyes
amoore131
Post by amoore131 »
Yeah definitely. Its pretty easy to get a WRX fuel pump for <50 bucks
wtdash
Post by wtdash »
Matthew - Sorry to Hijack -
Search this site for fuel pumps...the flows are listed. The WRX pump (@ least 'til '08) is no bigger than the stock turbo legacy's, so the only reason to get one is as a replacement. The STi is only slightly bigger, albeit sufficient for anything under 250HP, but I'd just get the Walbro 255 and be done w/it. You'll be good to go.
If $$ is more important, get an STi pump, but don't bother w/the WRX. You may need an adapter kit for the STi pump, too.
The REV chip is specifically tuned for the injectors that the Customer has when ordered (when it was still avl.). Since it uses the same 'logic' as the stock ECU it can probably learn between the small differences in injectors, but just like the stock ECU there is a limit to the learning.
There is info on here of people running 440cc, 480cc and even Sti 550's, w/some success on the stock ECU. I personally wouldn't go above the 440's, otherwise your gas mileage and performance will suffer. Running too big can be just as bad as too small an injector.
The stock WRX injectors are top feed, I believe and won't fit the stock EJ22T fuel rails...Not sure what you'd need to use them. Only the JDM 440's and 480's fit (Search on here). The STi 550's will fit the '92-'94 NA rails, and you can also use NA rails from the '96-'99 EJ25...maybe the EJ22, too.
GL,
Td
Turbo Subies:
'87 GL-10 Turbo - SOLD
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
wtdash
Post by wtdash »
amoore131 wrote:The site seemed active so I would assume so and I could add to cart but you would have to get to the checkout and find out I guess
Site is 'active' but not for purchases. If you create an account and check the Subaru forum you'll see a bunch of 'spam' posts in the Forum. This has been the case for months now. The owner hasn't been heard from since Feb. 2010 @ least.
Suggest you check out this POST and there is also a post called "The legacy of Revtronix" by BSOD2600, that I can't find.
Turbo Subies:
'02 WRX -SOLD
'96 BD-turbo'd-SOLD
'98 SF - NA-T
