Steering wheel
Steering wheel
Is it possible to put a newer steering wheel on a 92? I want to put a 07 stock steering wheel in my car and i want to know if its possible and whati I need to make it work. Thanks in advance
92 Turbo Legacy 2.2L
96 Explorer 4.0L
96 Explorer 4.0L
Re: Steering wheel
Yes I believe it should be possible. I'm not sure how the cruise control will hookup....if it will. I know others have done this, so they may be able to comment.
Re: Steering wheel
Alright thanks. What about the airbag though?
96 Explorer 4.0L
96 Explorer 4.0L
Re: Steering wheel
I have an 06 STi wheel in mine, real easy to do. Technically you're supposed to have a tool to do it but mine came off with a little force. Make sure you have the wheel dead center though when you remove it, otherwise you won't be able to line it up very easily.
Does the 92 have an airbag? If it doesn't it will take a lot of effort to make one work, if it does I'm not sure but it's probably just a couple wires, just make sure the battery has been unplugged for a while before you attempt that.
Cruise control I haven't tried, mine didn't work in the first place, so it'd be tough to tell if I wired it right.
Re: Steering wheel
Yeah be careful messing with airbags. They can kill you.
Re: Steering wheel
Oh trust me I know I go to lincoln tech and we did a lab on airbags and I know how to handle them without getting hurt
96 Explorer 4.0L
96 Explorer 4.0L
Re: Steering wheel
@ Apex3:
Where did you obtain your 06 STi Steering wheel? I'm assuming that one cannot order in a steering wheel with an active airbag via airmail or even surface mail as it contains what is considered by most governments to be an explosive charge.
Did you just pull it off a wrecked STi or buy it locally?
-= Facta, Non Verba =-
1993 Legacy L Sedan FWD [ FTL:( ] EJ22 with only 160,000KMs
Re: Steering wheel
My friend's car was wrecked, airbag deployed, so he got a Sparco and gave me his, I wrapped the airbag in suede and called it a day.KILO wrote:@ Apex3:
L-Tuned BD
Re: Steering wheel
On my '95 I replaced the old steering wheel with a JDM STi v7 Momo wheel. The airbag could not work because the yellow connectors (DIN) were different sizes. In 1998 Subaru changed to a different size connector plug in the back. I doubt it will be able to work on your '95.Potter wrote:Alright thanks. What about the airbag though?
Sorry my verbage is less than technical. Basically, the yellow connectors on the back side of the steering wheel changed sizes. '92 is smaller, '98+ being bigger.
The downside is my airbag light was constantly illuminated.
'95 Legacy BK - L - Original Owner - Heritage Rebuild
'93 Legacy BC - SS Sold
'91 Legacy BC - LSi sold
'95 Legacy BD - L Sold
'09 Legacy 3.0R - Sold
Re: Steering wheel
The splines are the same, if that's what you're asking.darkcrave wrote:So would 95-98 wheels works plug n play?
Re: Steering wheel
Airbag regulations for power also changed over the years and I don't know how or if that would have affected a change to the sensor design. Even if you could get power to a new unit, I'm not sure if you'd want to. Would it be a problem? I don't know, but it's something to consider.
